Sorry to hear that Sarah. Hope he's ok.
Let us know how he's doing Sarah.
What did the Vet say? Hope everything is OK. Have one that is not feeling too well either. Not sure what is going on with her.
On the truck side of things. Had to go to a Road Ranger yesterday & they were working on the pumps. For what ever reason
they were only selling premium, but at the regular 87 octane price. Cannot beat that. Saved $7 as that particular locations
premium fuel is priced accordingly.
He's perfectly healthy all tests say he's fine so we have him on medication to prevent any further issues and so far since his last seizure at the vet we haven't had any issues. Gotta take him back for blood work the 15th to see how the medication is taking to his body but he's been his crazy self so it's so far so good.
On another good note I ordered 35/12.5/17 goodyear fierce attitude mt through discount tire heard alot of good things and they're cheaper than the tires I was going to get. But I need to replace all my damn inner tie rods again...
Sent from my SM-G925V using Tapatalk
Glad he's ok! Great news!
Out here, even on stock vehicles it seems front end work is a never-ending saga. My '72 El Camino used to take these roads no problem, but all my newer vehicles, it seems like every year something in the front end needs replacing, even with Amsoil synthetic grease at regular intervals. They don't build the stuff like they used to. Our '86 Grand Marquis has over 130k miles on it's 10 year old ball joints (except one that I forgot to wipe the dirt off of). The tie rods inner and outer are roughly the same age, all over 100k miles. Guess it's a truck thing ...
Nope, my pickup has 127k on all original front end, other than wheel bearings. A ball joint boot finally tore though so it'll be time soon. Some others are looking a little fragile too.
Wow you did good there. My Silverado only made it to 38k. Went to get a sticker, and the inspector told me the lowers were junk. I didn't believe him, so when I got home I jacked it up and checked myself. Yep - toast!
I managed to get 50k out of my hub bearings, struts, and upper ball joints though. :lol:
Oh I'm not happy about the bad boot. I was planning on doing everything at once. Once in the air, one alignment and back at it for another 100,000
Damn that's weird. My old truck had 328k before I did any work to the front end (probably way overdue, bearings still good though) and my dad's 09 has 200k and no front end work
I'm solid axel swapping mine within a year I can't take it any more
I'm assuming mine got overgreased (probably by me) and that's the reason for the boot failing before the joint.
They're supposed to bleed off excess ... but lots of times when they're installed, the relief in the bottom of the boot is facing the direction that it's pressed down the most in, and will blow the thing out. It should face towards the hub/wheel.
The rack ends on my Silverado have no reliefs - the pressure stays in those forever.
I would hesitate before I bought any SFA vehicle as a daily driver. They're so much more complicated to work on than IFS. Yeah a 4 link Rock Jock 60 with high steer is great, but very few people run something built that well.
I'll continue enjoying being able to work on my front end myself.
Well after all the work in putting my driving lights back on the truck I found that they turn on anytime the headlights are on, high or low beam. I found out the wiring for the lights work a little different then my previous truck. I ended up putting a switch in so I can turn them on and off as I see fit. Still working on aiming them to my liking. Also I need to get a brace under the bar so they don't bounce around so much.
Minimal front end work on mine. :thumbs:
What is the average weight that you tow with your 2500HD? I've had to turn down some 18,000lb loads because my truck won't handle that. I'm looking to get another 2500, but wonder if the airbags help out the load enough to support that kind of weight, or I should just get a dually. Don't want the dually unless necessary.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
