6 hours ago, BadBowtie14 said:
I just modded up my Weathertech mudflaps with extensions, going hunting in a few weeks and have to drive about 80 miles on gravel.  Also,  I ordered a set of Go Rhino RB20 running boards, I liked shadrickjm's so much I had to get a set for myself.
This morning I repaired a 2005 Sierra Duramax HD cluster and a 2005 Silverado Duramax HD cluster , also sold them each a remote and programmed them to their trucks. Then repaired a FOB ( 15252034 ) for a 2008 Cobalt.  Pretty good day so far.
Cleaned out the garage and put away all the lawn equipment back in the small shed. Put all the lawn chairs back out, put the generator away along with the camp stove.  Now to put the rest of the extra fuel in the vehicles when they need it.  I got 20 gallons now to use.
New rear shocks and messed with the rear squeaking brakes
Ryan B.
Ryan B.
squeaky brakes...make any progress? Mine are gross after releasing the ebrake.
Basically cleaned em up used some spray from oreilly auto parts. It was an annoying squeal when slowing down. Took it for a short ride and noise is gone we will see
Ryan B.
Wagner Thermoquiet pads, by chance? I know of a tech who says he used to use those exclusively in his shop ... until every single one came back about a year later, squeaking and squealing like crazy.
If the squeal comes back, grab a bottle of Permatex Ceramic Extreme (the purple stuff), and use that anywhere the pads contact the calipers. https://www.amazon.com/Permatex-24125-Ceramic-Extreme-Lubricant/dp/B0018PSASU
I've lost count of the number of GM trucks from '99-'12 that have rear brake & E-brake issues. They should've stuck with drums. My '07 has drum rears, and that's about the only part of the truck that hasn't given me any grief.
Edited by Jsdirt
Look alot better than mine, that's for sure. They didn't look much better when they were 9, either.
Changed the gear oil in the Volvo. First time in my life I've ever seen a filter screen in a diff cover! Solid aluminum cover, too. I love this car more and more every time I work on it. Forgot to take a pic of the cover after I cleaned it. The differential looks just like a GM G80. 4:11 ratio - needs it to get out of it's own way, lol. 114 crank HP - about the only thing I can complain about.
Sure makes you wonder why Ford bought them ... HMMMMMM. Too good, maybe? Same with GM & Saab. "You take this one, I'll take that one" . Only reason this seems so plausible is because of the over-engineered crap everyone produces today. On that note, I just saw a Cadillac that needed a steering rack ... and REPROGRAMMING before it would work. ?
I was about to do the same thing with the rusty gas I pumped out of the neighbor's '03 Sable he entered in the derby. I was going to strain it and dump it in his Dodge, but he was too nervous about it ... so it'll go in my '94 s10 plow truck.
Can't believe this thing ran - the fuel line was kinked 90°! I was wondering why it took 3 hours for the fuel pump to move 6 gallons out, LOL.
3 hours ago, Black02Silverado said:
Topped my truck off with the left over gas that I have for the generator.
I usually do something along this line with my mower gas, at the end of October.  Surrendered my 2=stroke gas to the neighborhood landscapers, today, when they came by to clean up my yard, lawn equipment is still baried from our move, haven’t had the chance to get in the garage and clean/set-it-up, since the accident.
When I was a teenager, my dad and I would occasionally go to the junk yard for parts for his 72 Datsun pickup, and drain gas from some of the cars/trucks that had the parts we needed.  We would strain it coming out of the tank and again going into his truck’s tank.  BUT, definitely strain it putting it in the next tank.
Meant to ask, has everything healed up?
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
