Replace Door Handle
I have a 06 Silverado 2500HD, can you replace the front driver exterior door handle with a rear left door handle, I've had my lock punched in twice, one pre-alarm and one today with the alarm which I think scared them away because nothing was taking this time. I dont ever use the key always use key-less entry had it for about 6yrs now. I only hope I never return to a dead battery!! Or does anyone have any suggestions?
  • 3 weeks later...
The keyless left rear door handle will work.
You will need to swap the back piece, to the new handle.
Pull slow on the metal pin, plastic tab can break.
Remove the rod to door latch, so it won't rattle in the door.
One screw hole is 1/2" lower. Bend door metal flat with pliers.
Install nut on that screw, slide handle over bent area, tighten through door jam access hole with a 10 mm open-end wrench.
Don't worry about getting to battery. hood latch is easily opened.
Have an extra remote battery on hand.
Here is a few sites to check out for added security,
www.trucksecurity.com
www.autoguard.us click link to video.
