Bilstein Struts for Rancho 4" Suspension Lift
This is information that I could not find on this or other forums.
If someone is looking to substitute the rancho struts and shocks in their 4" lift kit for some Bilstein's these are the part numbers.
Front: BE5-E294-T0
Rear: BE5-6134-T5
I'm not a fan of the Rancho struts/shocks. As one of the rep's I spoke with on the phone called them "Watered down Monroe's", and I agree. These are built by Bilstein, distributed by RCD, and sold by various off road parts suppliers. I ordered mine through TGC because I've done business with them before. Thanks to the people at 4 different companies for their help in finding this information. The guy at RCD, I'm sure, knew the part numbers off the top of his head.
Hope this information helps others who might be searching for an alternative.
Thanks man, I've been looking for the correct part number myself. One of my shocks has had a rattle for some time now, and it sounds awful. How much was it for all four?
I'm glad you found this info, I've searched in the past and haven't had as much luck getting the Bilstein part #s.
Not that I dislike the RS9000 Rancho shocks...they just squeak like hell and it drives me nuts when the windows are down.
Where did you find these on the Top Gun Customz website....all I see is Bilsteins for 0-2" of lift
$408.95 shipped to my house.
Not listed on their website. I called and spoke with Jimmy Calhoun.
How do they ride compared to the Rancho's? I've never had bilsteins, but everyone seems to rave on how good they are.
New Rancho's are not bad. It's after a couple years/miles that I don't like them. I've found they don't last. The bilsteins seem to last forever and offer a "Sporty" ride. I've had bilsteins on three 4wd's and a couple of sports cars. I'm a fan of the value they offer.
Thanks for the info, I'll probably give them a shot.
Coilovers. Go big or go home.
/thread
I would love to have some, however I'm not sure I'm ready to drop the coin on those bad boys! How much did the Kings set you back? Nevermind, just googled it. Not as bad as I was thinking they would be. You know a good place to order from?
I was looking to get Camburg's after my lift. Maybe Christmas present to myself? King's for $1k? I might have to look into that. I'll probably stick with the Bilstein's for a while so I can get my AMP steps soon.
Wait.....coilovers such as the Kings are compatable with the Rancho lift? I wonder what size travel one would get to keep everything level, (ie. no Cali lean).
Probably going Bilstein here shortly but the thought of coilovers just sparked my interest.
Well it's going to be really hard to convince the wife that I NEED a 96 Corvette AND a set of kings! Especially since the Bilstein's are sitting on the floor of the living room wait to get installed.
I wouldn't need the Kings if Louisiana would put my tax money back into the roads instead of lobbyist pockets. Some guy's go rock crawling or desert racing...I go to Wal-Mart. Go figure.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
