lighting question
ive hooked up 3 offroad lights and im not happy with how bright they are so id like to upgrade the bulbs, i have these lights and their bulb number is listed as H3/100
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_chrome-off-road-halogen-baja-light-100-watt-%281-bulb%29-blazer_6250352-p#
i looked up these lights which burn whiter and am thinking about getting them
http://www.4wheelparts.com/Lighting-Lighting-Accessories/H3-100w-Xenon-Blue-Bulbs.aspx?t_c=14&t_s=67&t_pt=6065&t_pl=6718&t_pn=HLAH83135312
my question is these bulbs have a ground wire is this the wire that comes out of the back of the housing to ground? or is there a ground inside the housing as well as a ground outside?
I do believe that white wire is the power wire. The bulbs are case grounded.
first picture if it has two wires (one is hot, other is ground) other picture one wire is hot, Blub is gound to houseing. check PIAA, or KC lites they make good lites ? good luck
im pretty sure KC only has replacement bulbs for their lights, not aftermarket bulbs. PIAA has aftermarket bulbs.
my friend bought 2 PIAA lights and called PIAA and said they both broke (they didnt) and they overnighted 2 of the same lights for free.
have you looked into HID upgrades for your lights rather then just bulbs?
im upgrading the headlights on the truck to hids eventually, i think im going to go ahead and get those hella bulbs for my lightbar lights i took em apart and know what im doin now
Do some HIDS in your stock housings, do the all lights on at once mod. Then maybe think about some HID fogs, other than that after some 55watt HIDS for highs/lows/fogs you won't look back...
  • 4 weeks later...
I want HIDs and have been looking into it, it will get done after I take care of the lift
Sent from your truck via Tapatalk
