'99 Kawasaki Bayou 220. Bought it new in August of '98, and it is used mostly just for hauling deer out of the woods. It has hauled out tons of deer, and one time 3 at once. One on the front and 2 on the rear. I like it's small size as it allows me to snake through the woods where the big machines cannot.
Other than normal maintenance and batteries, I have only had to clean out the carburetor one time over the years. I put an inline gas filter in it after that, and never a problem since. She is an oldie, but a goody.
Here are a couple shots of it when I was turkey scouting a few weeks back.
Im probably going to get something similar to this soon. Sold the Polaris, it needed a lot of work done and it just wasn't worth spending the money on. I like the smaller utility atvs. I've owned a recon, a timberwolf, and a Suzuki Ozark. Probably get another recon, looking for one with electric shift. I like the smaller size being able to get in tight spaces easier and maneuver better. Most are pretty peppy, just lack top end speed but about 45-50 is probably as fast as they can safely handle anyway. The light weight makes them feel pretty sporty too and helps if you get stuck, just get off and push it out.
Posted my 93 Kaw KLF earlier (when it was clean). Did 92 miles over last weekend. Was a dust bowl in the mountains.
  • 3 months later...
Here is my 2008 Yamaha Rhino SE!! It's lifted 8 inches with Gorilla Axles, has 30" Terminator Mud Tires, Two Brothers Dual Exhaust and Juice Box, snorkeled, has the back seat, rifle rack, and roof with stereo built in!!
10364048_10152505471414740_3469868839947
2014 Polaris Ranger 800 LE ... It's still stock, but I do have a few toys on my Christmas list.
She's getting a 4500# front winch, when she goes in for her first service ... Anything you think might be cool to do with it, shoot me a link in a PM.
Here are some pics of my Kawasaki KFX700's. Both are far from stock. The red one is a 715cc with custom cams, a 40-shot of nitrous, and a +8" extended swing arm among many other mods. The blue one has a built motor as well, just not as aggressive. I also have 2 more that I just picked up to build up for trails because these 2 mostly ride only sand with the occasion trip to the sand drags, grass drags, or ice drags.
Edited by SilveREDo
This is my 2011 Honda Foreman. Simply put, this is a great work horse. It has hauled home many loads of firewood, taken me trail riding, and on hunting trips. It might not be the smoothest ride out there with the solid rear axle, but I love this machine.
It has the factory windshield, 4000lb Warn Vantage winch, Aluminum under armor (with stick guards), QuadBoss deluxe rear seat, both rear/front bumpers have been LineX'ed, Garmin GPS (with RAM mount), and Kenda Bear Claw tires. I love this time of the year the best as it allows me to spend time on the back of this bike hunting and firewood cutting.
10665178_10152691543756397_6787636877912
Here's our ATV.........mine and the wife.......both have the rad kit mod....!
DSC00739
DSC00840
Finally! another outlander owner!!
Sent while in 'Murica...
2013 Ranger XP 900 - 4 inch lift with arched a-arm, w/34x10x15" terminator tires, HD front brush bumper with 5K winch, HD Rhino axles front and rear.
2014 RZR XP 1000 - No lift but has 34x10x15" Terminator tires, custom exhaust for belt box, SSV 6 speaker audio system.
These are my RZR 800's I sold:
2009 RZR 800 - 8" lifted with 31 Outlaw Tire and many other modifications
2011 RZR-S - 3" lift with 29.5 outlaw tires
DSC and Chevy Boy, now those are REAL ATVs. Good work vehicles. That's what I want.
Here is a workhorse 85 250ES Big Red.
Spent 20 years on a cotton farm before I got it from my grandfather. The kids think it is cool because I have pictures of me and my brother on it when we were about 5 yrs old; It was in a little better shape back then. Never been in the motor. Still runs like a champ.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
