Thanks. I need a good working machine that is trail ready as well. No racing, but good all around use. Plowing in the winter, good fun in the summer in the mountains. Looking for suggestions.
  • 5 weeks later...
Here's my bike. I wish it had an odometer on cause the miles would be unbelievable. Love my 300's cause they just refuse to die!!!!
I was pulling my 2016 Polaris Ranger with my old 14 Silverado, and am looking forward to yanking it around in my new to me 14 LTZ Z71.
13932731_626139344212185_301431705099446
14063982_636653989827387_649174641375873
Edited by IMPALADAKID
What size trailer is that? 570? 900? Do you trail ride the Ranger?
The trailer is a 5x8. I lengthened the back by the gate to accommodate the extra length of the Rangers Bed. The Ranger is a 570 Midsize with a 3500 lb winch. Yes we do, and it serves double duty around the house as well.
Thank you! How does it handle in the trails? The bench comfy?
Yes. Fairly comfy. It handles surprisingly well. I can say I spent over a year researching UTVs to get one that both functioned well on the trail, and around the home as a yard vehicle for under $10,000. The Ranger just stayed at the top of my list. I had an open cup of coffee in the cup holder. I drove over a few bumps that in anything else would have had me wearing it, but as far as I could see when I stopped, not drop was spilled.Over all, I could not be happier with the machine. It just does what I expected it to do, and does it easily.
Here it is at work cleaning the mess left in the sheds the previous owner left for us.
13494950_609033712589415_618951736291624
And here it is on the same trailer before I extended the gate back a foot.
13310637_600084193484367_812202670807255
Thanks! That $10,000 price point is where I like to stay also.
If I don't go ATV again, will be an Ace or Ranger.
Split the difference, and go with a RZR 570. You will thank me.
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
