6" Fabtech lift with Fuel 20x10's on 35x12.5 Nitto Terra Grappler G2's
That looks great! Any issues with the MRC on install?
Ordered my 20x12's, should be here Tuesday. Thinking about the toyo rt 35/12.50, and Mcgauphy 7-9 black ss lift unless anyone else has better ideas
From all the research I have done, McGuaghy's is a really good ride and supposedly better than BDS, Rough Country, and the cheaper lifts out there. Occasionally some people have gotten bad rear shocks with the kit and have had to send them back in for another set. If you got the money then you should get Bulletproof or Full Throttle Suspension, but that price is nasty haha. I got the 7-9 McGaughy's SS black kit in with a add a leaf to set at 9" and got a 1.5" Zone body lift. Just waiting on my 22x12's and 37x13.50s to come in and hopefully will have her up in the air in a week or two.
Thanks for the reply, can't wait to see the end result when you get yours done. Really hoping to improve the looks, and ride. Hoping I don't need the extra leaf with it set at 8".
Looking for suggestions on rubber. Currently happy with the nitto Terra grapplers, looking for something a little more aggressive looking, but not wanting full on mud terrains rumbling down the highway at 80.
Someone suggested toyo rt's, any feedback would be greatly appreciated
Hey guys starting to build my truck I have a 2015 all terrain I'm undecided between 3 kits looking at the 1. 6in bds with coil overs 2. Fts 7in with coilovers or 3. 6in fabtech performance with 2.5 dirt logic coilovers. Any help on which to go with
(Before) 2.5" leveling kit
6.5" zone lift, 35x12.5x20 Toyo open countrys on stock 20's with no spacers, at full lock both ways and in forward or reverse no rubbing AT ALL!!
Four Wheeler Network seems to be impressed with the Cooper Discoverer STT Pro. It is a mud tire, but they say it has good road manners with only a slight him.
Those look, and sound awesome according to the article, thank you.
http://www.fourwheeler.com/product-reviews/1511-cooper-discoverer-stt-pro-super-traction-tire/
Oops, thank you
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
