Yes i checked youtube.
Yeah I'm sure I was just jokin
Which one to get? 6 inch fabtech or 7-9 FTS lift? Supposedly the 6 inch fabtech is actually a true 7-8 inch lift. So if that's the case which one would you pick?
its all personal preference
Anyone with the zone 6.5 or any 6 inch lift for that matter have front driveshaft vibration when in auto or 4wd on the highway? Only use it when roads are bad but i get a vibration and hum. Especially on deceleration. Thinking about trying to find a dual cardan drive shaft. Truck is a 16 sierra.
Sent from my SM-G903W using Tapatalk
nope I don't
I notice me does it when I kick it down to pass or just letting it breathe a little. Didn't do it with stock tires on 4" lift but after I put the 35s on I noticed it.
10/12" Full Throttle Suspension..
4-linked rear with coilovers.
/end thread lol
It's your ride but...........what the hell!
?? It's the cleanest truck here most likely.......
Different strokes for different folks haha. I think it looks cool but I would never in a million years do that to my truck. I just appreciate the work that goes into it and the passion people have to build that stuff
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and maybe memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.
