18 minutes ago, 14 Silvy said:
Where’s the best dea on the CST 4.5 stage one kit ? I just bought a 2018 Silverado and think I wanna go that route due to not increasing track width.
I bought mine from Performance Lifts. mainly because I bought my last lift there for my 2013 and they have great customer support. New Level motorsports has it a little cheaper then Performance, I think they are around $1650. for the stage 1 kit.
Cant wait to see it. Strongly considering this lift and squeezing some 35s. Love that it doesn't increase track width
Sent from my SM-G950W using Tapatalk
I’ll post a bunch of pics once it’s all cleaned up and can compare the before shot
To the new shot....
Pic coming soon [emoji13]
I’m also looking at keeping the same Nitto Ridge Grapplers 285/60/20’s (33.7’s) but may go up to the 285/65/20’s cause I want to have less drag from the tires width wise but a bit more height for a softer ride, I don’t know [emoji1745]‍[emoji3603]
Sent from above
30 minutes ago, chrispassas21 said:
I have the fox 2.0’s not exactly sure what they are set too. Don’t think they are the same as bilstein to adjust like that. Sorry about that
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
The Fox 2.0's adjust with a spanner wrench, mine are at 2" because I was just leveling my truck when I installed them. Yours most likely are at "0" otherwise you would have gained an extra two inches of height over the 4 1/2" CST spacer.
To the new shot....
I’m also looking at keeping the same Nitto Ridge Grapplers 285/60/20’s (33.7’s) but may go up to the 285/65/20’s cause I want to have less drag from the tires width wise but a bit more height for a softer ride, I don’t know emoji1745.pngemoji3603.png
Sent from above
Looking forward to the pics!
One thing is for certain, (and I know lifts, had many of them) it seems to be a much heavier duty and very thick steel, highest quality paint job I’ve ever seen from any manufacturers suspension components. Very impressed!
Sent from above
That’s not including rear shocks for the 3”-5” lifted applications.
Sent from above
2016 Silverado Z71 Crew Cab. 6” Pro Comp lift kit. King Coilovers in front. King shocks in rear. 20” Pro Comp wheels w 35x12.5 tires. Borla Atak dual side exit exhaust. 51882a33086725c9597b8a444bf9a8d5.jpg8b57b99c93083b64bbf552d865aa9093.jpg8a66fca1e191d9eadb88ad9eedf43462.jpg
Damn i love a nice set of kings they look bad ass. Nice truck man
Ok, how’s the ride quality of your Kings, stiffer, mushy?
Sent from above
Sent from above
Best money I ever spent on a suspension. Feels like a Cadillac. Both front and rear are adjustable so I can make it stiff or mushy. I’m set in the middle with no complaints.
I’ve heard great things about King suspension. First I was looking Fox, then did the CST lift so naturally just about jumped on those but I’ve heard such great things about King suspension and now you, lol. I’m interested to know which stock# for the 4.5” lift would work as well as the rear which currently running 3” blocks, looking at going 4” just cause it’s perfectly level but I like a slight rake up front. Do you know your model #’s?
Sent from above
Just decided to go with CST full adjustable coil overs. Their amazing quality is out of this world but 100% made in The USA [emoji6]and will only compliment my awesome CST lift [emoji631] Thanks for the input!
Sent from above
On ‎11‎/‎15‎/‎2018 at 2:31 PM, TXGREEK said:
Just decided to go with CST full adjustable coil overs. Their amazing quality is out of this world but 100% made in The USA emoji6.pngand will only compliment my awesome CST lift emoji631.png Thanks for the input!
Sent from above
Just wanted to ask if you have the lane keep option on your Sierra?  Came on my LTZ with the forward collision alert. Just wondered if  any problems with the lane keep after installing the CST kit.
Edited by SSchup
correction
Great question, No issues at all. Well, maybe, constant desire to do more upgrades lol. In all seriousness, absolutely ZERO problems, as far as mods on my truck, best decision I made was the CST lift.
In the constant desire to do more, these just arrived
Front
Rear
Awesome craftsmanship, second to none
If you do end up doing the CST lift, get the Stage 1, this way you can do whatever shocks and struts you want and when and if you want to add CST coilovers like me, you’ll have the CST upper coilover, strut and spacer assembly as backup or spares.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
