TBagan, what pro shop did you use so I know not to go there since I'm in Austin too.
I finally installed my 5k hid kit on my 14' sierra and imo they look great. I removed the intake box and removed the connection that sits on top. Put everything back on.. hids work great. . When testing the lights I accidentally turned the truck on with the intake box removed and not plugged in and the truck turned off by itself. So hooked it all back up. Turned on but check engine light is on. I drove it 10 miled didn't come off. Any ideas? Similar issues? Or should I disconnect battery?
I would just disconnect the battery for a few minutes. Or even try unplugging and then plug back in any connections that you undid when installing the HIDs. Maybe something didn't get plugged back in correctly
If you don't have a code reader that clears codes, get one. It'll save you a lot of BS in the long run and maybe some $ along the way.
Hey...where can I get one of those code readers that clears the code..good to have...please let me know where I can buy one? Thanks spurshot.
http://www.ebay.com/itm/Actron-AutoScanner-Plus-CP9580-w-CodeConnect-OBD-II-CAN-Vehicles-BRAND-NEW-/121352790767?hash=item1c4130a2ef&item=121352790767&pt=Motors_Automotive_Tools&vxp=mtr
I have this one and it work awesome on all my vehicles... :)
The one in S. Austin, Andy's something.
There is one in PFLUGERVILLE. I'm still not happy. He adjusted something and the shine down about 10' in front. Not to mention I noticed moisture in my fog lights today.... Yep don't go there!
You can find them at about any auto parts store. Read the features. Some only read codes. Some read codes and clear codes.
Just slightly OT, but I think it goes to the main subject here. I drove my wife's 2013 Flex Limited with HIDs last night for the first time in months. It really has great projectors and HIDs. They are a single bulb, shutter type hi/lo. Excellent side lighting. However, it does have some lighting that goes very high when the high beams are selected. So, there's hope out there. A good replacement projector and HIDs. I was starting to doubt the projector type lights could work as well as the reflector types. They can.
I'm not sure if the reflector housing is much different from my 2011 to my 2014 silverado, but I can say this...HID's in the 2014 reflector housing are ok until it rains, I couldn't see very well at all the other night in the rain.
Sent from my SCH-I545 using Tapatalk
First time downloading photos. Fxr projectors with 55w ddm kit and d2s morimoto 5000k bulbs. Thanks to block8head for his advice on install. It is as straight as I can get it. Took several tries. The fxr projectors tend to bow upwards.
Sent from my SPH-L900 using Tapatalk
it's been 6 months since installing the 55w ddm kit. 80amp relay that came with ddm kit had to be replaced twice. I replaced it with a 40amp relay better quality and no problems since. I also had the right headlight blinking rapidly so I replaced the canceller on the right side and it also happened on the left side a short while later so I also replaced the left side. both left and right side cancellers were replaced with after market from ebay and not ddm.
I had an FXR retro on my 2011 f150. Those are really good projectors.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
