^ Your Sierra hates you.. LOL :D
Have you checked the fuses?
I thought about those. But I went and plugged in the stock halogens and they worked. Or I atleast put in the drivers side cause I did not feel like dealing with the air intake
Definitely check the fuse going to the battery connection and then the relay.
I just went out and rechecked all the fuses. I realized that last night I completely forgot about the inline fuse. I checked it and it didn't look blown, but it looked like it had better days. So I changed it out and the headlights work again. Thanks y'all!
Sorry, meant to quote you, not myself, in my last post
Has anyone tried to retrofit the Yukon Denali HIDs into the Sierra yet?
I would think it would be a lot cheaper and probably less work to retrofit in some FX-R projectors. And probably better output after the fact too.
Likely would be...something to be said for swapping in OEM (almost) parts though. Peace of mind, if nothing else
Yea but I think the peace of mind you are thinking of is if there is a warranty involved...when you start hacking up headlights....aint no more warranty.
Edited by fondupot
Yea but I think the peace of mind you are thinking of is if there is a warrant involved...when you start hacking up headlights....aint no more warranty.
I must agree. No more warranty. When you do anything to change how a certain part came from the factory. It's not always easy to get the warranty to be honored. Even if you put a genuine GM part. It's still a GM part, but it's not really where that part was intended to go
I think Baxter was referring to peace of mind knowing that the parts have OEM quality and durability. Aftermarket products can range from way better than OEM to completely worthless. Many aftermarket mechanical products don't have the reliability of OEM.
I took my HID kit off my 2010 Silverado to try and re-use on my '14. After looking at the kits on page 1 of this thread, I don't think mine has a relay. There are just several plugs and a ballast for each one. It's a 6000k 35w kit and I'm thinking all I need is to add some capacitors to make it work right. I just couldn't find any pics/descriptions of where/how to put in the capacitor.
After reading through many pages of this, I don't think I need to reverse polarity, since I'll need 2 capacitors. So where do they go? Would you need to see pics of my kit before answering? If so, I can post this afternoon.
Picked up my Sierra Thursday and wow I love this thing except everyone is right about how horrible the headlights are. My 2005 I traded in had better lights. I had HID in my 05 for 6 months 9 yrs ago with nothing but issues and took them out. Just went with Silverstars.
I have read through this thread and I really want HID but it looks like the issues still exist but some have no issues at all. Who has had HID installed without issues? What type/part#s do you have? Motomedic knows what he is talking about for sure so I want to get Morimoto ballast and a 4300K bulb. What else do I need and where do you buy them? Also do the ballast cause the static reception with the radio like my old ones did 9 yrs ago?
Where is the "inline" fuse located?
The inline fuse is on the hid wiring harness that connects directly to the battery for power.
It is located between the battery terminal connection and the relay
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
