Check out theretrofitsource.com and hidplanet.com for retrofit tips and installations. The headlights will have to be baked in the oven to soften the seal, and pry the lens off. Then you can add whatever projector you want. You don't need to have ltz projector headlights already.
Just wanted to say thank you to FastWS6TA for his recommendation on fog lamps. Got the lights fast and had great communication with him and his coworker.
Thanks bud. Enjoy!
Sent from my SM-N920V using Tapatalk
Decided to create a new section on our website to help save people some money. It's called the bargain center. In there (at the moment) we have some group buys setup for the FXR kits for 2014/15 Chevy and Sierra. Essentially it will yield you about a 20% savings or right around $65. All you need to do is make a group buy purchase (in full, not a deposit). Once 10 buyers have purchased the group buy will be complete and start over. If you purchase you need to be mindful that your discount is due to the group buy discount. Until the group buy is complete nothing ships. A group buy may take a few days to a month to complete. If you are in a hurry this is not for you unless you and some buddies can rally and all head over to the site and make your purchases. In the unlikely event that you have been waiting a month we will email you and give you the option to receive a refund.
We are hoping that this new offering will help save folks money. If you look at the stock status you can see how many more purchases need to be made till the group buy is complete. These numbers will be updated twice a day. Here is the link
http://www.fastheadlights.com/mobile/Category.aspx?id=1899
Can you tell me about these:
2014-15 GMC Sierra 1500/2500/3500 FXR retrofit kit
I have a 2015 Sierra SLE. I hate my headlights
Can you tell me about these: 2014-15 GMC Sierra 1500/2500/3500 FXR retrofit kit
This is a very popular kit we have been selling for over about 2 years now. Have sold a few hundred. Many members on here have retrofitted their lights using this kit. The fxr is a tremendous improvement over the factory projectors. Probably rates about a 5 out of 10 difficulty wise for the install.
Installed morimoto hid today 55w 6500k
Damn I wish I would have done this a long time ago
What exactly did you buy/install?
I purchased an hid kit with the capacitors and the single relay harness. I did plug the capacitor between the buld and ballest then ballast to the realy harness and the light did not work.
They only work with out the capacitor, but when the DRL is on the bulbs flicker.
So as for now I have to shut off the auto lights during the day.
When I first bought the set up I thought I only needed the capacitors. And of course the light only worked when the truck was off, then shut off when the truck was turned on. I tried flipping the wires every way possible but just one way cancelled the other way to keep the light on or not work.
So wtf is the correct way I've seen vids and don't get it why my light don't work.
Ok I'm going to bite the bullet and buy new GM projector LTZ headlights but want to make sure that it uses the same plug connector. Does anyone know?
I feel pretty certain that GM wouldn't have two different bulb sizes on different trim level trucks. They should all be H11 for the low beams and 9005 for the high beams. Even if for some outrageous reason they are different you can typically find adapters to change from one style to the next for cheap on the internet (amazon.com, ebay, etc.).
No not what plugs into the bulb but the harness plug in the back of the headlight housing that connects to the main wiring harness.
The only other thing that should plug in on that assembly would be the running lights and I didn't mention that in the previous post but they should all be the same plugs assuming your WT has running lights (I am not familiar with the WT trims). If for some reason they are not you can get adapters to make them work for about $10. It really should just be a plug and play as long as the LTZ assembly will fit. I believe the only swap that has been done on this forum is putting the LTZ assemblies in the LT trims.
I haven't found anyone that has installed the LTZ projectors into the Work Truck Trim but I have seen a few LT to LTZ swaps and everyone says they are plug and play so you should be okay. I am posting a link to a similar thread below:
http://www.gm-trucks.com/forums/topic/153376-2014-silverado-headlights/
So I bought my hid kit from the retrofit source. I bought the Silverado specific one for my truck. Silverado '15. My kit did not come with the resistor thing. On the online intructions it shows one should be included. Oh and I also have a slight humming or buzzing sound that goes away once I turn off the hids. Idk if that's related to not running a resistor or what not
Just wanted to see if others running the same kit did get that resistor thing. My lights flicker here and there but for the most part stay on fine at night. Just installed last night so I can't call trs to ask them
Thanks
Edited by Avinad
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
