Front Brakes
During the last month I have put, roughly, a thousand miles on my 2010 Silverado 1500 while towing a trailer (without trailer brakes) and carrying load. After a some hard emergency stops from slightly above highway speeds, I now have a slight vibration in the brake pedal only when stopping from speeds around 50mph and above. I have a feeling that I didn't warp the rear drum set up. So since I usually replace things before they really need to be (I hate slight vibrations) I was looking at replacing the front pads and rotors. I know the vibration is not wheel weight related because during my last oil change before the trips I rotated and rebalanced all the wheels. I have not thown any weights and I mark the tire near the rim with a paint pen because the new weights are a pain to hammer on so I know they haven't moved. My cost for dealer OEM pads and rotors (non-economy AC Delco's) is $248.60, or should I go with a brand like EBC and get yellow pads and sport rotors for $294.25. I have 42k on the truck, what do you guys think I would have better luck with?
  • Replies 30
I personally like the "Baer Eradaspeed" rotors coupled to "Hawk HPS" pads.
Also consider replacing the rubber brake hoses with "Russell" stainless steel wrapped hoses.
Your rotors are warped. Nothing at all wrong with the pads unless their worn out (doubtful). If you don't tow an unbraked trailer like this all the time and this is the first time this has happened, I'd just have the rotors turned and move on with life.
I'm having the same issue, except this will be the second time I've replaced the front brakes. I'm tired of wasting money on crap brakes from oriellys. Is there a heavy duty option for a 16" wheel and 6lug bolt pattern? I was considering going with something like wilwood or brembo, but I haven't seen anything made for a wheel smaller than an 18". Gurrzt and Bruce, have you pulled a trailer and put some abuse to those brakes? I'd like to know if they can handle more than the vehicle alone. Thanks, Rudy.
I pull from 1000lbs to 2500lbs all the time and the Green stuff pads are night n day from stock. I also add the Platinum Pro Stop rotors from Pep Boys. Im doing the rear brakes this weekend.
rotors definatley warped.. replace before the pads get messed up
If his rotors are that warped that he can feel the shimmy, he should (in my opinion) replace the pads at the time of the rotor installation. The rotor warpage probably wore down the pads unevenly.
By replacing the brake pads with the rotors, he can "mate" them together properly per the manufacturers instructions.
JMHO
JMHO
Agreed, I could turn the rotors at work, but why make warped rotors even thinner? I see it quite often where the tech's turn rotors that they usually comes back with a pulsation not too long after ( probably already under min. spec). I know that the pad's still have plenty of life on them, but they will still get replaced with the new rotors. I have been looking into the Baer Eradaspeed rotors with Hawk pads. I like the improved stopping power but it is costly. However, that's nothing compared to a collision repair from hitting a deer or what not that could of prossibly been avoided. The only problem is that there are few reviews on the rotor kit and I don't want to run into any issues.
Your life is worth more than the price of the rotors and brake pads, when it comes to these components "you get what you pay for".
I have had this setup on Sara (2001 Z28) for over 10 years, and have not experienced any problems with warpage or excessive brake pad wear.
I have Powerslot slotted rotors and Hawk LTS pads. I've had them on the truck for about 1,000 miles and I'm about to take them off. They squeal something awful in the mornings, they squeal at low speed stops and they occasionally squeal while driving. I won't buy Hawk pads again. I've had them checked by two different shops and they said everything looks great and the pads are wearing evenly. I've also bed them in twice. They also dust like crazy.
I'm keeping the rotors but will be replacing the pads with Akebono's soon.
I did some research recently on some of the most popular pads for our trucks and found out that the friction rating for all of them are the same. The Hawk LTS pads have a rating of FF. The Akebonos, Wagners and all AC Delco pads are FF as well (called each company directly to confirm). Not sure on EBC but I would assume the same. Even though they are considered "performance pads", they have the same rating as all the other pads for our trucks. Not much difference in performance for double the price vs a good ceramic. Go with a quality ceramic pad and good rotors. They will have much less noise and much less dust and still stop just the same.
Once I get the Akebonos swapped in I might get some stainless steel lines but we'll see.
Baer just responded to an email I sent them. They say that their Eradaspeed rotor upgrade kit fit OEM rims that are 20" plus and that my 18" won't work with their set up.
I have the EBC green stuff and it stops on a dime.
I'm very happy with my EBC Greenstuff pads. I've had them on for around 1000 miles now. I haven't tried slotted rotors, I don't like anything that traps dust. I do think it would be a good idea to just go ahead and replace yours, even if you turn them I bet the vibration will be back.
What about PowerStop? I put them on my last truck and they were great while it lasted. I didn't do anything more than daily driving with them though and the truck was totaled about a week after I got them on.
What's the gross trailer weight you are towing? Single axle trailer? The gross towing weight along with any cargo (your buddies, the kids, dog, wife and/or girlfriend, etc.) you have inside the truck will impact braking performance. So will braking going down hills over longer distances. Excessive heat buildup can easily lower braking performance. A few panic stops should not be a big issue with regards to disc pad and/or brake shoe life assuming your trailer weight is fairly small (like a thousand pounds or less).
When I had my '99 Silverado with 4 wheel discs, I towed an open car trailer with a gross weight of 5600 lbs. The trailer had brakes on both axles. When I traded that truck in on my current '08 Silverado, the '99 had 77K on it and still had a good 40% left on the original pads. Never had any issues at all with the factory brakes.
My '08 (also with 4 wheel discs) has 41K and I now have an enclosed trailer with a loaded weight of about 6800 lbs. The OEM brakes look like brand new. The rotors are smooth, no ridge at the outside edge and no signs of any cracks.
If the rotors are warped, there is no way to machine them. You can go with AC Delco rotors as a replacement or look at Raybestos "Professional Grade" rotors available from Rockauto. There is nothing really wrong with the current line of GM brake pads for their pickups. Of course, the dealer wants a ton for them, but they are available from other sources like Amazon or Rockauto.
    • I only have a few of the ACDelco blue remaining. One or two of the (old, old) ACDelco Professional boxes, and a couple of the newer style GM boxes with the simulcast in Chinese along with English. FWIW they've all been pretty good, regardless of where they are made, and in 20 years I've never had a problem with an e-core filter.   Now I have a couple of the "A" series in my home inventory. They come in a plain white box with the GM hologram sticker and model information. Have not installed one yet, want to use up my oldest inventory first.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
