Sounds good, have any of yall tried the rancho quicklift leveling shocks, similar to the bilsteins but it comes fully assembled with coil springs and everything. Bad part is its pretty pricey at $400
yes. I have rancho quicklift and rs9000xl on rear. U can view a whole thread on this titled rancho vs bilstein or rancho quicklift loaded. There are two threads
Sent from my iPhone
using Tapatalk
and yes it rides awesome. I had RC leveling kit before. Now rides awesome. U get what u pay for
Sent from my iPhone
using Tapatalk
wow... long thread and now I am more confused than ever. I am looking for pics that are running stock 18's. I am looking at either a 2 or 2.25 in level with either 275 70 18 or 285 75 18 ...I only have a 4.3 so really don't want to go much bigger, just looking to level and get a little more clearance for hunting some back woods places. thanks
I'd like to know if anyone has done this also. I'd like to stay around the 2.5" lift mark
I have an AT with my Air dam taken off, factory Molded flaps, and my step bars taken off. I've got a pic in the 2014 Pics thread to give you an idea. Its also my Avatar pic
I too would like to change out the stock ranchos with the bilteins. I really dislike the ride after the 2inch RC spacer. I really need to get to around a 2.5 up front. Has anyone left the 2inch spacer on and mounted the bileins on the lowest or 1rst setting?
Sent from my iPhone
using Tapatalk
Fuse36 , do you think you could fit some 275/65/20 with the Ranchos ? Or a 295/55/20 without rub ?
yes 295 55 20 wouldn't be a problem. I believe 275 60 20 would also but not sure on 275 65 20
275 65 20 is 34.07" and 295 55 20 is 32.78" and 275 60 20 is 32.99".
I installed the Rancho Quicklifts today and my wheels and tire should come in tomorrow. I'll be running 18's. We'll see if my combo works?
What size tire? After doing some more searching I might just save up a little more for the Rancho setup. Also, What brand of tire did you get, I am looking at a few, one is the Falken A/T and the other is Cooper ST Maxx.
I'm going to try 285/65-18 Nitto Trails with 0 offset.
Edited by WTXZ71
Theres a comparison for u
Please keep us posted, I am using the stock rims, I need to find out if the offset will work. I am interested in the 285 setup you are doing and my other choice is 275/70-18
also curious why you didn't go with 285/70-18, its 33in. Do you think there wont be enough room?
thats actually 33.71" so it might rub. That's close
thanks, I should be good with 275/70-18 then, really looking hard at the cooper st maxx, only problem is all the snow we have I couldn't work on my truck for a little while anyways.
I have the 275/70/18 on stock rims. I went with the Hankook Dynapro. So far so good. No rubbing. We got a ton of snow and they have done really well. They look fairly aggressive but not too noisy. I'm pretty happy with them. I did measure my truck after installing the Bilsteins. 38 to front fender and 38.25 to rear. It's damn near level. I'm running lower air pressure right now with the foot of snow we have on the ground. It may come up a little more once I start playing with more air pressure. The tire dealer only put 37 lbs in the tires and I think I'll take them up to 45 and see how it rides once the roads clear up.
    250.3k
    90Nine4One
    90Nine4One
  • Who's Online   3 Members, 0 Anonymous, 719 Guests (See full list)
