I hear you. I wonder if 285/75r18's would be better or worse. They're a half inch taller but about a half inch narrower (than 290/70r18).
I've got a level in box still that needs to go on, I was hoping a 1/2"s spacer would be enough but that would put me around +18 ish. may just have to get new wheels...[emoji2] I was hoping to stick with the stockers as I like them.
I've got my set i just took off for sale, its a very good set up if you're interested. only about 6 months old on both tires and wheels
^^^^14x4 that's the size I run wanna run and I read all the pages a while back and its a popular size 285/65/18 I might pull the trigger and just get that on fuel mavericks with toyo open country on 2.5 rough country
285/75r18 or 285/65r18? I don't think I've seen anyone run 285/75, it's a pretty tall tire and only Nitto and Toyo make that size I think.
Just wish someone was running 285/65/18 on fuel mavericks with toyos or cooper stt and leveled I really want to run that but like to see pics first ahaha
Be careful with Fuel wheels, not saying all of them do this but theres been a bunch of ppl complaining about them cracking and not holding up off road and this was told to me by several tire guys that would know
More pics, in pic 2 it shows a good idea where it rubs when u reverse and turn, it barely hits that button screw at the bottom but that can be fixed and as u can see theres more room than expected towards the front, i trimmed just to be safe
I'm on my 8th set of Fuel Wheels covering 5 vehicles the last 3 years. NO issues at all. Its all in how you treat them. I had 2 sets of XD wheels start peeling and fading.
    ncleg
    ncleg
  • Who's Online   2 Members, 0 Anonymous, 1,458 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
