Put on the 1.5 zone body lift with the 2.5RC level waiting on call for my tires to get in!
Anyone put a 295/60/20 on with a 2" RC level? Willing to do a little wheel well trimming if needed?
U can go to. 34 inch tire
I will be running the Cooper Discoverer STT, which I am currently running in the 33X12.50R20. Their 35s measure out to an overall diameter of 34.65, so they should be okay.
Mine r 34.25 and the about 1/2 from body mount and only 12 inches wide.. they did rub liner zipped tide them back .. but I have 2.5 level and 1.5 body .. so I'm 3/4 higher don't sound like much but everything counts .. hope they fit :)
Sorry thought it was the guy with 2 level and 1 1/4 body .. but it just depends on the true measurements of tire .. Mine say 34.7 but really only 34.25 on a 9 inch rim..
I wont be doing this until my current 33's run out of tread life. Then I will be doing the body lift and 35's. From now until then I could find a different tire that I like and will hopefully measure out closer to your size tires, may have to go with a metric tire size. I am glad to see someone has succesfully completed what I had in my mind. All the 4 wheel/off road shops I have talked to have told me that it was not possible to fit a 35 inch tire without a 6 inch lift. I will be glad to prove them wrong once mine is complete.
Just purchased a 2014 sierra 4 wd double cab with P 275/55/R20 tires and wheels Want to install Billstein 5100 leveling shocks on the front to level the truck. 3" is the number in order to be level but unsure of what ring adjustment to use on the Billistein to give the desired level .
Also would like to hear from a member who has made this change and the end results of the change reguarding handling and ride.
Thanks
I have 5100's on my truck, they are set at the top notch which is 1.85". I installed a 1/4" spacer under them to give me about 2 3/8" lift. I wouldn't go over 2 1/2" of lift in the front, because the angles of the suspension won't like it…
I find the ride quality improved greatly with the 5100's and I'm very happy with them…
New B to this forum. I have read through most of thes 163 pages of posts - however i have yet to see anyone with my "hopeful" set up.
2014 Silverado LT Crew Cab. I purchased the Rough Country 2" Leveling kit, American Eagle Series 015 20x9 wheel with a +25mm offset. Will this fit a 295 55 20 tire? I dont want to Rub or Cut. Whats the largest tire size i can go with?
I am being told that a +25 will sit like a rail road car as it sits in way to far, a lot of cutting will be needed as i will be hitting everything inside with a 31" tire.If that is the case i will return them as i want to run as i want to run a slightly larger tire.
Thanks and look forward to posting some pics of my new set up sooner then later.
I just got a 2015 Silverado 1500 Z71 and am wanting to lift it. I found the rough country 3.5" lift and am wanting to know more bout it. It comes with aftermarket control arms. It comes with a differential drop and new differential skid plate. Does anyone have pictures of this kit with 0 to +18 offset rims
my rims are +12 witch I think helps I would like -12 but don't like my black truck all chipped up .. I don't rub anywhere but liner and that's an easy fix.. was going to go with a 295/60 but they where just to high when I could get these for 100$ less a tire .. I will go mud tire next
I previously had this exact size Toyo Open Country AT2 on my 14 AT.
With OE wheels which are 20X9, +27 offset I had minimum rub on sway bar at full lock.
Good luck on purchase.
Ok thanks.
I've been told that I should go with a 305 50 r20 hankook dynamo at rf10 as a lot of thr other tires that want are 10 ply and are gonna ride pretty rough. I'm no looking for a monster truck with a rough ride, but want it to look slightly more agressive then stock.
Anyone run these tires?
thinking of leveling out the front of my truck 3" and then getting airbags for the rear instead of blocks. Am also looking at dropping the differential to help out the cv angles. if I was to drop the diff at a different time, would changing the cv angles cause me to have to have my truck realigned?
Thanks
    Clark_Elite
    Clark_Elite
  • Who's Online   4 Members, 0 Anonymous, 384 Guests (See full list)
