lockey14s Posted November 5, 2015 Posted November 5, 2015 Where did you get the 1.75" rear block? The RC website lists the block in the 2.5" kit as a 2" rear block. Does the kit actually contain a 1.75" or did you use a different block? I had the RC 3.5 kit installed for a little while but didnt like the ride quality and it caused some steering issues. So i took it out of the front, but left the back block in. I thought it was 1.75" over stock but cant remember for sure. It does give the truck a nice little rake though. planning on putting in a zone 1.5 body lift to get it where i want.
Jackseric Posted November 5, 2015 Posted November 5, 2015 I had the RC 3.5 kit installed for a little while but didnt like the ride quality and it caused some steering issues. So i took it out of the front, but left the back block in. I thought it was 1.75" over stock but cant remember for sure. It does give the truck a nice little rake though. planning on putting in a zone 1.5 body lift to get it where i want. It looks great. Don't suppose you have a pic directly at the side while it's sitting on level ground?
lockey14s Posted November 5, 2015 Posted November 5, 2015 It looks great. Don't suppose you have a pic directly at the side while it's sitting on level ground? thanks, if its not too dark after work i will get a pic
baggedlvintegra Posted November 5, 2015 Posted November 5, 2015 Sneak peak of the new setup on my new truck 1
lockey14s Posted November 6, 2015 Posted November 6, 2015 It looks great. Don't suppose you have a pic directly at the side while it's sitting on level ground?
Jackseric Posted November 6, 2015 Posted November 6, 2015 PAINTED 3.jpg Man that looks good. It's darn close to level with just a slight rake. You still rocking the factory tires? What size are they?
lockey14s Posted November 6, 2015 Posted November 6, 2015 Man that looks good. It's darn close to level with just a slight rake. You still rocking the factory tires? What size are they? thanks! no where close to completion but its a start. waiting to wear out the factory tires (275/55r20) and then putting on toyo AT's 295/55R20
MTB10 Posted November 6, 2015 Posted November 6, 2015 Just got my new truck, lifted it and put tires on right away. GMC Sierra 2015 Elevation Edition Lift: Rough Country 2.5 inch level with RC rear block Tires: 275/65/20 Toyo Open Country C/T (34.3") Very happy with this choice was going to go with the BFG KO2 but they are on back order till the end of the month. The Toyo's are great a bit louder then KO2 but ride good. Pics: When I got it: After lift and tires: With air deflector on No air deflector: Will get better pics up tomorrow 2
cjz28 Posted November 7, 2015 Posted November 7, 2015 Just got my new truck, lifted it and put tires on right away. GMC Sierra 2015 Elevation Edition Lift: Rough Country 2.5 inch level with RC rear block Tires: 275/65/20 Toyo Open Country C/T (34.3") Very happy with this choice was going to go with the BFG KO2 but they are on back order till the end of the month. The Toyo's are great a bit louder then KO2 but ride good. Pics: When I got it: After lift and tires: With air deflector on No air deflector: Will get better pics up tomorrow Got specs on the Ford my friend wants a setup like that
BlackZ71Silverado Posted November 7, 2015 Posted November 7, 2015 For some reason I really like the look of that F-150. That's the best looking Ford I've seen in quite a while. Sent from my crappy iPhone 6 using Tapatalk
MTB10 Posted November 7, 2015 Posted November 7, 2015 Got specs on the Ford my friend wants a setup like that Here is the whole thread on his build: http://www.f150forum.com/f118/my-2015-lifted-platinum-283217/ 1
cjz28 Posted November 7, 2015 Posted November 7, 2015 Here is the whole thread on his build: http://www.f150forum.com/f118/my-2015-lifted-platinum-283217/ Ah thank you sir! I prefer yours BTW, looks great!
BowHunter1 Posted November 8, 2015 Posted November 8, 2015 Great looking set-up MTB!! And I have to agree with the others about the F150....it too turned out very nice! 1
CptMcSaug Posted November 8, 2015 Posted November 8, 2015 More pics: First sweet truck and digging the GTR! Second, whats the measurements of the fenders to the ground on the front and back? 1
