I have the rough country 2" leveling kit ready to be installed, but I'm concerned how the truck will look once the leveling kit is installed and when I pull my 28' travel trailer. I dont want to be one of "those people" that looks like their TT is too heavy for their truck and makes the rear look saggy...
Do an "add a leaf" or airbags and you will prevent that all together
I had a 2.5" Rough Country with rear blocks installed this week. I had 275/65/20 BFG KO2s installed today. I wanted to try 285/75/20. I think they would probably fit.
Does anybody know what measurements the alignment should be after a level?
whats up new in here, just got my 2015 Tungsten Silverado double cab LT. Want to throw on some Fox 2.0 IFP leveling shocks. I believe those are good for 2.25 level. Wondering if +31 offset wheels will rub with 295/55/20 or 305/55/20. Anyone input much appreciated!!! Thanks
just got my Silverado the other week. this past Saturday night my neighbor and I installed the rough country 2.5 kit along with the new wheels. started around 8 finished at midnight. We took our time and enjoyed some silver bullets during the process. Love the result, exactly what I was looking for. seemed like a quality product and install was fairly easy. I have been wrenching on muscle cars since I was 15 ( currently 31) and this was my first "lift/level kit" had a few beater trucks in the past, always wanted a nice Silverado but could never ever live without a GM V8 car. finally got to a point in life where I could have both!
Did you stick with the stock shocks? How about the rear block did you add that?Also did the leveling kit come with rear shock extender mount for the shock itself?
New to this site I have a 2014 Sierra Denali I want to put a 2.5 front 1 rear with 285/60/20 on a stock off set does any one have this setup or know will it work without rubbing
285/60/20 should be fine on stock set up with a 2.5 kit
Eventually when my stockers are shot I'm going to go 295/60/20
Yes I kept the stock Rancho shocks. I removed the 1 inch rear block from the factory and put in the 2inch block RC supplied.
In the 295/60/20 I like the toyo open country AT 2, in my second choice 285/60/20 I like the Goodyear Duratrac
I was looking at those same tires there doesn't seem to be a whole lot for the 285/60/20 but I haven't looked to hard at tire brand yet still trying to figure out what size I want to run
I am currently in the process of deciding what rims and tires to get for my truck as well. I installed a 2" Zone leveling kit, and I am going to get 20x9 Fuel Hostage, and I finally decided to go with the Deegan 38. It has an aggressive look and is under $300 per tire, plus reviews are great for on road, off road, and in the rain and mud. i also like the look of the toyo MTs but the price puts them out of the picture. Good Luck
Do u have pics of truck with the fuel hostage wheels I really like them wheels
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
    • So, lot's of googling and reading, and a trial fit found, that indeed they hit the newer fatter caliper. I did some re-testing today, and found just 3/16" worth of washers was enough for the wheel to spin freely. I added 2 more on each, and again it spun freely. Tested lock to lock with the 4 washers, about 5/16" not quite the 3/8" Im considering, but pretty close. No issues. I've been looking at the BORA .375" spacers and using extended lugnuts to get back lost thread due to the spacer. All the ET lugs I've seen are all .33" reach inside the wheel lug holes. For those that don't like spacers or think they're unsafe, I think it depends on what type of spacers you're using and making sure you get good quality hubcentric ones, and if you're using bolt on ones, regular mainenance, checking the spacer lugs. Not wanting or needing that much spread. Looking for the minimum that will let me run these rims and tires.  it does look to stick out a little, but I really want put these on. and use the stock all-terrains in the winter.
