Will this set up rub the sway bar?
Here are 2 pictures with the Rough Country 2" Level with Bilstein front adjustable shocks set on the lowest setting. BFG All-terrain 305/65/18
Edited by black 08
Bilstein 5100's are in my truck! I think they look awesome and the ride is so much better than stock. With my old shocks, I'd get a jarring feeling when I'd hit a pothole or sharp bump in the road. The 5100's definitely smoothed that feeling out. I really need to get them on the rear now.
I will post pics and measurements when I get a chance.
On stock tires the front measurements were 36-1/4" and 36-5/8" before 5100's.
What setting did you go with on your shocks?
Hey guys, I've been contemplating what size wheel and tire to put on my 2015 Silverado. I have a RC 2.5 leveling kit but im scared to get a tire and have to trim a lot. I want to put a 20x10 with a -24 offset and either a 305/55r20 or 285/55r20 BF Goodrich Ko2. Can someone give me some advice on which one to go with?
have you thought about a 305/50/20 or maybe a 295/55/20?
Will 305/65/18 bfg ko rub sway bars on a 2014 Silverado 2 inch level?
Bfg site- 33.5 x 12..2-18
Edited by black 08
I have, but the that tire only comes in the 285/55 and 305/55, I have seen posts on custom offsets where people have fit bigger tires on that wheel but i dont know if i can trust that.
there are other good all terrains out there besides the BFG. Personally, i like the General Grabber AT2 over the BFG, but i didnt check what sizes they offer. May want to look into Nitto Terra grapplers or Toyo Open Country AT's. I have Nitto's and am happy with them.
I finally got some better shots!
  • Like 4
Hey geswek. Which level it did you use. Any track addition or still stock
I went with Motofab 2" block under strut--nothing more; still on stock Z71 Rancho shocks.
Rides just like it did before lift--rigid enough that I enjoy it. :)
Ok; so mark the 12-o'clock and then rotate it clockwise one whole turn? Clockwise lowers and counter-clockwise raises?
That's what I did and I don't seem to be blinding people now.
Sent from my Nexus 5 using Tapatalk
I went with max height setting on the shocks.
Measurements are as follows:
Before Lift
Front left = 36.25" Front Right = 36.625"
After lift
Front left = 38.25" Front Right = 38.5"
This is still with factory Goodyear SRA tires. I will be adding BFG KO2 275/60R20 in the next week or so which should add another 1/2" to those heights.
    C. Hart
    C. Hart
  • Who's Online   1 Member, 0 Anonymous, 467 Guests (See full list)
