It's going to be a daily driver as well, only pulling a trailer on some weekends. Just looking to level it for the rest of the time
Just one of the many reasons a set of airbags is a good addition for anybody who ever hauls anything heavy with these trucks. You don't need to drive around with 3" of rake all the time just so it'll be level when towing.
2015 Z71 4X4 SLT Sierra
RC 2.5" leveling kit with the under the coilover spacer installed.
Still on the stock Goodyear SRAs.
I plan on installing the spacer for the top of the coilover and replacing the factory rear block with the block included with this kit before I make a decision on the tires.
275/65-20 or 305/55-20 BFG KO2s?
I like the height of the 275 and the width of the 305, unfortunately the BFG KO2 doesn't produce the size I would like in a 295/60-20.
I drive 55 miles one way to work.
Edited by tcdawg
275/60-20 or 305/55-20 BFG KO2s?
Truck looks great! For that kinda driving stick with a 275/60/20 and make sure its a P rated tire not L. Save some gas.
Thanks!
That's a typo. It should read 275/65-20.
Edited by tcdawg
That's actually a typo, it should read 275/65-20.
I have same truck as Robvas and put airbags and compressor on works great pulling trailer or loaded truck
Edited by dunnp650
does RC make a body lift for our trucks, I looked but couldn't find it on their sight. I was thinking about doing the 2.5 RC level with a 1.5 in BL to run 305/70/18 or 285/75/18 on stock rims, any opinions on this setup as far as rubbing, thanks
Edited by rhodeislandhntr
If you're driving over 100 miles every day, then I'd go with a more conservative tire size. Something like a 285/55/20 or 275/60/20 will give you a better stance than stock without killing your MPG and driving manners.
I agree 100%.
Stopped by a local shop today to price a leveling kit and was told $400 + $100 for alignment. Is that the going rate? Sounds high to me.
It is either high or low depending on what you are buying and where you are getting it installed. For $500 (cdn) I can get a 2.25" Ready Lift kit installed and aligned at my dealership. I suggest shopping around as I have found a $200 price spread on basically the same work
Question: I just received these today 20x9 with 0 offset 33/12.50 tires, and I don't get my RC2.5 level kit installed until Monday. This Friday I have an appointment at the dealership to have them road force balanced, and was wondering if I could get by the weekend with having the dealer throw them on for me. Would just be a little in town driving, and currently I have 22x9 +15 offset 305/45/22 tires and don't rub. Thanks
    250.6k
    Aries68
    Aries68
  • Who's Online   7 Members, 0 Anonymous, 434 Guests (See full list)
