Any of you guys have any shortcuts or pointers on installing the lower blocks of the RC 2.5 level? Didn't find many good quality videos. This kit, as bad as I hate to say it, kicked my a$$ tonight! I got the top spacers in but I pretty much did everything short of disassembling the whole entire front end tonight.
After spending a few hours doing my AMP Research steps, I decided to tackle the level also... Now I wish I hadn't! I am admitting defeat and bowing out gracefully! I'm not new to suspension work, but its mostly been limited to coilovers on sports cars, never any lifts or levels.
Jack one side up and support with jackstands.
Take off tire.
Disconnect steering joint.
Disconnect brake line on upper control arm
Disconnect sway bar nut or at least back the nut off as far as you can.
Discconnect upper ball joint nut (UCA)
Discconnect top strut nuts
Discconnect bottom strut bolts and pry off nutplates and discard.
Put in top spacer but only put the nuts on top of the strut on very loosely so you have play for the bottom.
Put in the bottom spacer with bolts from the top--threads down. I remember having to pry a little to get the holes lined up, but not bad.
The hardest part to me was compressing the strut to get the upper ball joint nut started. I hooked a ratchet strap to the top of the strut and the lower control arm until I could get the ball joint nut (UCA) started.
http://www.silveradosierra.com/suspension/2-5-rc-level-kit-install-2014-gmc-sierra-t350650.html
Take off tire.
Thanks for the reply. Top spacers were no problem. It was the rear bolt by the axle that had me kinda baffled. The directions said something like, you may have to move the knuckle to one side to gain clearance from the axle, or something like that. The lower control arm was bottomed out as low as it would go, and there's no moving the axle. I'm about ready to just have it done somewhere. I live out in the country so all my friends are 50 plus miles away. So needless to say, I was pretty frustrated! Edited by gSwift
Just front spacer.
Did you get a wheel alignment after? Was it necessary for just the top spacer?
I used the readylift video on YouTube. It is simple video on how to put there 2.25 leveling kit on but very similar to the rc kit. Took me about 3 hours from start to finish.
Sorry forgot to say I used this video to do my rc kit on the 16 gm and worked like a charm.
Well, the ready lift video showed me everything except for the lower block installation...which is what I need. The bolt by the axle seems so long that I see no way of getting the bolt in. I can get it in from the bottom up all day long. I'm beyond frustrated trying to get this lower block in.
Show pics of what you are working with please. I've installed a full RC 2.5 on my previous 2014 Silverado and I managed to do it all with simple tools and a 1/2 ton floor jack lol, i'm willing to guide you but would need to see what you're seeing.
I appreciate the offer and the replies, but I called it quits and put the front end back together. As I mentioned before, i'm certainly not new to suspension work, but this one got the best of me. I'll take it to a local off road shop as bad as I hate to.
But just to try and clear up what I'm saying. The main thing that was giving me trouble was mounting the bottom block on the bottom of the shock. I calls to put the new bolt in from the top side, and I can get the bolt in on the hole nearest to the front of the truck. But the back hole of the shock is almost directly under the axle. Therefore the is trying to go in at a hard angle but the head of the bolt is hitting the axle.
All bolts I put in on my readylift kit had them going in from the bottom up. This allowed for me to reuse the threaded clips that are connected to the shocks that act like a nut you could say. So for u to put them in from the top down makes me wonder how you would be able to use the factory threaded clip? Did the send nuts to go on the bottom of the spindle?
I would suggest putting the bolt in from the bottom up. My two cents.
You don't use the threaded clip on the RC kit. You just pop the clips off and then they supply you with new bolts and nuts. Your kit sounds like it makes more sense. And I could go in from the bottom, but the bolt is so long and the lock nut so thick that its jamming into the bottom of the axle.
Guess i'll just leave it to the pro's haha
Edited by gSwift
The bolts have to go in from the top. I think the problem is that you didn't take off the UCA nut completely and drop the hub.. I had the same issue. I tried to leave it on by one thread and pry the lower spacer in under the strut. Once you take the UCA nut off and the steering tie rod end off, you can articulate the hub any direction you want to get the bolt in.
As I think about it, I may have done the bottom spacer before the top spacer. The first side took me forever it seemed, but the second side was like 30 minutes total.
Here is my strut down before I took off the UCA and dropped it completely.
Edited by bcbz71
That may indeed be the issue. I was leaving the UCA nut attached, and by more than a thread or two. It seems as if I had watched a video where they took a couple of shortcuts and left that nut attached. But now that I think about it, I believe they went in from the bottom with the new bolts on the lower spacer.
Thanks for the reply! I think i'll give this one more try before I give up.
If only I had followed the directions word for word :banghead:
Get'er done!
    ncleg
    ncleg
  • Who's Online   4 Members, 0 Anonymous, 803 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
