Any of you guys have any shortcuts or pointers on installing the lower blocks of the RC 2.5 level? Didn't find many good quality videos. This kit, as bad as I hate to say it, kicked my a$$ tonight! I got the top spacers in but I pretty much did everything short of disassembling the whole entire front end tonight.
After spending a few hours doing my AMP Research steps, I decided to tackle the level also... Now I wish I hadn't! I am admitting defeat and bowing out gracefully! I'm not new to suspension work, but its mostly been limited to coilovers on sports cars, never any lifts or levels.
Jack one side up and support with jackstands.
Take off tire.
Disconnect steering joint.
Disconnect brake line on upper control arm
Disconnect sway bar nut or at least back the nut off as far as you can.
Discconnect upper ball joint nut (UCA)
Discconnect top strut nuts
Discconnect bottom strut bolts and pry off nutplates and discard.
Put in top spacer but only put the nuts on top of the strut on very loosely so you have play for the bottom.
Put in the bottom spacer with bolts from the top--threads down. I remember having to pry a little to get the holes lined up, but not bad.
The hardest part to me was compressing the strut to get the upper ball joint nut started. I hooked a ratchet strap to the top of the strut and the lower control arm until I could get the ball joint nut (UCA) started.
http://www.silveradosierra.com/suspension/2-5-rc-level-kit-install-2014-gmc-sierra-t350650.html
Take off tire.
Thanks for the reply. Top spacers were no problem. It was the rear bolt by the axle that had me kinda baffled. The directions said something like, you may have to move the knuckle to one side to gain clearance from the axle, or something like that. The lower control arm was bottomed out as low as it would go, and there's no moving the axle. I'm about ready to just have it done somewhere. I live out in the country so all my friends are 50 plus miles away. So needless to say, I was pretty frustrated! Edited by gSwift
Just front spacer.
Did you get a wheel alignment after? Was it necessary for just the top spacer?
I used the readylift video on YouTube. It is simple video on how to put there 2.25 leveling kit on but very similar to the rc kit. Took me about 3 hours from start to finish.
Sorry forgot to say I used this video to do my rc kit on the 16 gm and worked like a charm.
Well, the ready lift video showed me everything except for the lower block installation...which is what I need. The bolt by the axle seems so long that I see no way of getting the bolt in. I can get it in from the bottom up all day long. I'm beyond frustrated trying to get this lower block in.
Show pics of what you are working with please. I've installed a full RC 2.5 on my previous 2014 Silverado and I managed to do it all with simple tools and a 1/2 ton floor jack lol, i'm willing to guide you but would need to see what you're seeing.
I appreciate the offer and the replies, but I called it quits and put the front end back together. As I mentioned before, i'm certainly not new to suspension work, but this one got the best of me. I'll take it to a local off road shop as bad as I hate to.
But just to try and clear up what I'm saying. The main thing that was giving me trouble was mounting the bottom block on the bottom of the shock. I calls to put the new bolt in from the top side, and I can get the bolt in on the hole nearest to the front of the truck. But the back hole of the shock is almost directly under the axle. Therefore the is trying to go in at a hard angle but the head of the bolt is hitting the axle.
All bolts I put in on my readylift kit had them going in from the bottom up. This allowed for me to reuse the threaded clips that are connected to the shocks that act like a nut you could say. So for u to put them in from the top down makes me wonder how you would be able to use the factory threaded clip? Did the send nuts to go on the bottom of the spindle?
I would suggest putting the bolt in from the bottom up. My two cents.
You don't use the threaded clip on the RC kit. You just pop the clips off and then they supply you with new bolts and nuts. Your kit sounds like it makes more sense. And I could go in from the bottom, but the bolt is so long and the lock nut so thick that its jamming into the bottom of the axle.
Guess i'll just leave it to the pro's haha
Edited by gSwift
The bolts have to go in from the top. I think the problem is that you didn't take off the UCA nut completely and drop the hub.. I had the same issue. I tried to leave it on by one thread and pry the lower spacer in under the strut. Once you take the UCA nut off and the steering tie rod end off, you can articulate the hub any direction you want to get the bolt in.
As I think about it, I may have done the bottom spacer before the top spacer. The first side took me forever it seemed, but the second side was like 30 minutes total.
Here is my strut down before I took off the UCA and dropped it completely.
Edited by bcbz71
That may indeed be the issue. I was leaving the UCA nut attached, and by more than a thread or two. It seems as if I had watched a video where they took a couple of shortcuts and left that nut attached. But now that I think about it, I believe they went in from the bottom with the new bolts on the lower spacer.
Thanks for the reply! I think i'll give this one more try before I give up.
If only I had followed the directions word for word :banghead:
Get'er done!
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
