2.5 rough country level w/ 285/75/18 toyo ats on stock Sierra wheels.
Any rubbing with that size tire? I'm looking at doing the 2.5 RC on my stock 18's as well. Was thinking of the 275/70 18s
In case anyone is looking for more data points on lifts, wheels and tires. I had a 2.5" Rough Country Level/Lift kit installed... and then installed 295/55R20 Toyo Open Country ATII Xtremes, with Fuel Maverick 20x9 Wheels in a +14. After having it done... I should have gone with the +1 offset... which would have stuck out an extra 13mm's, which is .5" inches. I would have loved to gone 305/55R20's... but I wanted to keep the Chevy mudflaps... and they would had to of come off. The 295/55R20's fit with an 1" to spare!
Let's see
At first glance that looks like a 2500. Looks good.
so to make a long story short..ive wore my eyes out reading the headlight threads already..now onto leveling it.
which kit is a front leveling only that isn't just reaming down the torsion bars or wont have the upper control arms hitting the frame at full extension. I have a 15 crew 2wd. sle. just like it to be level ..maybe even by removing a rear spacer?
thanks
Hey guys I am trying to go for this guys build (link below) although maybe a little less aggressive tires (ill take suggestions I want an off road look but don't want damper daily driving, because its really never gonna go off road just like the look). Also is there any difference between the 2014 1500 high country and the 2015 high country?
https://www.customwheeloffset.com/wheel-offset-gallery/8223/wheel-offset-2014-chevrolet-silverado-1500-aggressive-1-outside-fender-leveling-kit-custom-rims
thanks
No torsion bars on these trucks. Cheapest option and what your probably looking for any front spacer kit, try Motofab, Rough Country etc. They are all pretty similar. Either a top or bottom spacer, some are a combination of both once you go above 2.5ish inches.
Next option is Bilstein 5100 leveling shocks.
Most expensive is Fox, King coilovers etc.
No mechanical difference for leveling, wheels etc 14 to 15 that I know of. Id just copy what you see there. As for tires those are MT(Mud Terrains) if you want less aggressive go to an AT(All Terrain). Most popular are BFG KO2, Toyo Open Country AT2 , and Nitto Terra Grappler.
I have a 2.5" Rough Country Leveling kit... with 2.5" in the front and the 1" spacer in the back... and had no issue installing 295/55R20 Toyo Open Country AT2 Xtremes on Fuel Maverick 20/9 +14 offsets.
20160416 154121[1]
20160418 085331[1]
thanks..spacer kits are easy enough
Removing rear block is an option as well. Think I saw a 4wd guy do that somewhere on here.
So the suggestion (from the company) is to go with 305/55/20 BFgoodrich all terrains KOs on the 20x10 -24 fuel mavericks, everywhere I've read 305s aint gonna work with a 2.5 level?
what did ur wheels and tires cost you if you don't mind me asking
$2,900 out the door. Tire were like $350 ea.
Does Anyone know the fender height on a 3.5 level running 33's?(2014 Silverado LT)
Edited by Pigster
I'm looking to do this exact set up. Feel free to post more pics. Looks perfect
Not the best, but at least it's not in the driveway. I love the final product.
Sent from my Nexus 5 using Tapatalk
    TopBo
    TopBo
  • Who's Online   6 Members, 0 Anonymous, 843 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
