Yes, conservatively, I would agree with that. You might be able to squeeze more, but it just depends. There seems to be some minor variation between individual trucks too. I was originally going to go with bigger tires, and when I saw the stock setup with the level, I thought it looks great as-is. Plus, unlike on the 20's and 18's, the factory tires on the 22's are larger (285 vs 275) and really nice. They are also an AT tire, not a regular tire, so unless you plan to go mudding (unlikely with 22's and a Denali) I don't think a change of tires is needed.
BTW, you should look up the piping mod and do it to your truck. Some blue piping would look sick that that blue exterior. I did the grey piping on mine and it looks amazing.
Did a search and nothing What Piping mod?
That is a sexy ass truck!!
Sent from my SM-G935V using Tapatalk
Sent from my Nexus 6 using Tapatalk
I saw you driving on Day Blvd by Columbia Rotary in South Boston on Tuesday around 5pm. Recognized the color and that grill right away. Truck looks great.
Haha that's awesome!
How is everyone's gas milage after a leveling kit and tires? I was thinking about putting some 295/55/20s or 275/65/20s on my truck with a rough country 2.5" level. I commute 80 miles round trip. This is what my truck looks like now.
And this is what I would like it to look like
15/21 with 2" and stock tires. That's on Winter gas.
Edited by '17 Sierra
See here I selected stamped arms, the top spacer is now a circle. See the part number? Now in second picture it says strut doesn't need assemble but excludes that part number. Like I said before, the rough country rep said they changed top spacers for stamped arms to help the geometry/angle a little better apparently.
Hello I bought for my Silverado RC 1312 , who are installed wiht this ? my truck have stamped steel control arms
Edited by gastonhector
Gastonhector: with that kit You have to disassemble the strut to install the .5 spacer. Or just drop it off to a shop to install.
Edited by Criscone
How is everyone's gas milage after a leveling kit and tires? I was thinking about putting some 295/55/20s or 275/65/20s on my truck with a rough country 2.5" level. I commute 80 miles round trip. This is what my truck looks like now. 9d8d140f930cc5649bc0361de2e5c46b.jpg
And this is what I would like it to look like 5eba3f60e94bc7ef31c0e2b90f8d5916.jpg
That looks to be a lot more than a 2" level in last picture. that's like a 4" lift? Edited by Criscone
What is the offset? Do they rub at all? Trimmed? I am looking to do 33x12.50R20 with either -12, 0 or 12 offset 20x9 wheels.
Just stock wheels so I'm not sure about the offset. Whatever they come with I guess. But no rubbing and no trimming at all. Didn't want to do any trimming so I was nervous about it but they worked out perfect!
Progression of my 2016 Z71. Hopefully this helps some members decide on how far to go.
Stock
2" RC Level with stock wheels/tires
2" RC Level with Gear Alloy 20x9 and Toyo ATII 295/55/20 (Very smoky that day due to wildfires in our area).
Cleaned up
2" RC level with Zone 1.5" Body Lift. RC steps added for the wife. Having exhaust pipe raised next week.
  • Like 8
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
