Here's mine with 20x9 Mavericks and 295/55 Toyos, RC 2" in the front only
What kinda gas milage are you getting now man?
Did you have to make any changes to the body lift for it to work? I have a 17 and called Zone Friday with a response that the 14-15 body kit won't work on the 17. But, it's the same body style as yours.
Sent from my SM-G930R7 using Tapatalk
I actually had to make fewer modifications. The bumper does not have to be modified, only the bumper mounts on the truck. The only real difference was, I needed to notch the frame (where the e-brake cable passes through) more than the instructions state.
Finally got the leveling kit installed this past weekend. Looks good, should've done it sooner, a lot sooner.
Edited by 15BlueSilverado
Slightly off subject but i have a stock 2015 1500 LT. I want too put 22x12 inch rims on it. I was wondering if this would work and what the max tire size i could put on?
Finally put in rear blocks and bags.
2" front RC level
2" rear blocks
20x9+15 wheels
275/65-20 ko2's
No rubbing.
How would 295/60/20 fit on a 2016 Sierra Denali 1500 with a 2.5 RC level?
I dont know if there is any definitive answer for this, but how high can you go on a level with bilstein 5100 IF you get aftermarket UCA?
Mine are adjusted to the 2nd from highest setting, with 1.25 top spacer (netting about 2.5") and 1" higher in the rear (5100s also)
I know they say never go above 2.5 on a level or your ball joints will hate you -
---- My question is - WITH aftermarket UCAs, can i go to that top setting on the bilsteins, yielding about 3.25" in the front without having any issues? If so, is there anything else i would need to do (besides obviously an alignment)?
I had a 2" kit (front only) put on when the crap stock tires were ready for replacement. Up sized the tires to 285/55r20 Falcen AT3's. No problems rubbing at all, rides great. Wish I did this a long time ago.post-171580-0-60474000-1491776134_thumb.jpg
Edited by Dandizzle1371
Theoretically you could, but you're going to bottom out your shocks a lot quicker since they're not extended travel shocks.
Upgrade to an extended/lifted version of the 5100 and you should be fine w/ aftermarket UCAs.
Finally bit the bullet last week on tires. I ended up going with the Falken Wildpeak A/T3W's, and I will say in person they look better than expected. For the price, its hard to argue against them. They are very quiet and smooth, and the truck rides exactly like it did with the stock tires.
I went with the 305/65/18s because 285s look so tiny on these trucks. They measure 33.6x12, and somehow I dont rub at all with zero trimming and a 2" level. Here are before and after pics. I will eventually post better pictures, because these dont do it justice. It looks beefy in person.
C6679838-0AD1-444A-B887-9DF634183BCE_zps
C19D3885-5663-4E54-B49F-1A732A5E6C1C_zps
8907C925-1FD9-4BD9-AC96-95D02731B9C2_zps
9A16E782-89B3-424F-9BF3-0F5C5381F265_zps
C183AB6C-232F-4086-A648-9A597D5CBB28_zps
Edited by rawalters117
Those look awesome!
2" RC front level
XD Grenade 820 wheels 20x9 +0 offset
Falken wildpeak at3 tires 305/55/20
Edited by Criscone
2" RC front level
Truck looks great, did you have to any trimming or do you have any rubbing going on with the new setup. Looking at doing a similar setup on my truck.
Thanks,
Bob
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
