On 1/26/2018 at 4:51 PM, DenaliLegend said:
Thanks! 285/55r22 and get a small rub on full lock on liner only
Damn, wouldn't think they'd fit without harsh rubbing on a leveling kit
Here's a pic of my leveled 2018...
3" leveling kit on 275/60/20, removed factory block in the rear.
What’s up guys I went with a motofab leveling kit 3inches in the front 2 in the back did it myself but fursure a lot easier with two people 44a68958d320f1ad6b1deb02890ddf3d.jpg
2018 crewcab Silverado 2” RC leveling kit. Thinking about 295/55/20 Nitto Ridge Grappler on stock wheels, anyone running these tires with this setup?
Any wider than a 275 on your stock wheels will rub the UCAs on your 18 with a leveling kit. If you look you likey are already rubbing slightly on your UCAs now on stockers. 295s will fit in that 295/55R20 height-wise but width will give you trouble.
Sounds like maybe going to a 275/65 or 60 might be a better fit.
On 1/10/2018 at 7:16 PM, SirenRed16 said:
If you remove the rear block that'll only give you like 1 inch. If you want perfect level you have to buy lowering shackles. Both of these trucks have a 3 inch drop in the rear.a45530fbd42120b73c4d94ccaa369295.jpg550829c858b445602deffab5fe6f9d5b.jpg
Sent from my SAMSUNG-SM-N920A using Tapatalk
Is this 2" shackles and block taken out?
No it's a 2" shackles and the block flipped under the leaf springs. If I had removed the block I would of had to get longer u bolts.
any pictures of the block being flipped? I'm really new to this truck thing and I like how those trucks sit with the rear drop. I've seen 2" shackles with .5" block, is that about the same?
Edited by silvy2k17
It'll be the same but the trucks I posted have about 3" of drop. I'll try and get you a picture.
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
