I've ran two different level kits on my 2017 Sierra so far. First I purchased the Readylift 2.25" level with tubular UCA's which I ran with 275x65r20 Ridge Grapplers on my stock wheels. No rubbing and I was very pleased with the setup. After a few months I decided to buy aftermarket wheels and tires which were the Hostile Sprockets 20x10 -19 offset with 33x12.5r20 Toyo RT's. Major rubbing with the new wheels. I bought the Motofab 2.5" top mount spacers used from my friend and had a shop install those which took a lot of the rubbing away. Still rubs in reverse at full lock..very happy with the new look. The readylift 2.25" level gave my truck a slight rake which I liked. The Motofab 2.5" level gave my truck a totally leveled look which I've grown to like more. Attached are both setups.
First picture is the Readylift 2.25" level with 275x65r20 ridge grapplers on stock tires. No rubbing. Slight rake.
Second picture is the Motofab 2.5" level with 20x10 -19 Hostile Sprockets with 33x12.5r20 Toyo RT's. Minor rubbing. Perfect level.
  • Like 4
Tint is done. Now looking into levelling the truck.
Looks great!
I hear ya. I have 2.25 as well. Front is still quite a bit lower. Ext cabs have so much rake. Think ill add a bit more as well
Sent from my SM-G950W using Tapatalk
Any rubbing?
Sent from my Pixel using Tapatalk
Negative [emoji1303]
I leveled my '18 using Bilstein 5100 on the max setting (about 2") and my headlights were off a bit.  I parked next to my brother's '16 and aimed the lights on his garage door about 20ft away.  It only took like 1-1.5 turns of the adjustment screw to bring it back down.
Clockwise or counter?
I decided after reading here to go with the RC 2" and also Sumosprings in the rear on my '18 crew.  Will have them in the next couple days.
You just get it? Very nice looking truck.
Thanks.Had it for a few months. Had black and milled fuel mavericks. Decided to try the stockers with witg bfgs. Im glad i did
Very pretty color. Mine came with 22’s, dealership owner just threw them in for me, had them removed to 20’s then I got a billet aluminum 2.25” level front 1” rear added. Threw on KO2’s then the rubbing started. Got new 20X9 Fuel wheels with a +18 and the rest is history.
Forgot to mention, the rubbing happened cause the new 16-18 have the stamped steel UCA’s and the new tires were 275/60’s not the stock 55’s. I’m glad I did cause I got sick of the stock chrome wheels really fast.
Thanks! They are 285/65r18
What size tires? Your truck looks amazing.
    • Kudos? Are any of them desirable? Class leading (in any metric)?
    • Those are great questions, Bill. Our team looked into your VIN and it doesn't appear to have AFM or DFM. Please know, we take the personal and private information of our customers seriously, and we don't recommend posting your full VIN publicly. As for Auto Stop, some vehicles have a button to turn Stop/Start off for one ignition cycle. If the vehicle is equipped with the Stop/Start deactivation switch, you can push the switch to turn off Stop/Start. Stop/Start is turned off when the LED indicator on the switch is not illuminated. If you have any further questions, please visit https://s.chevy.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
