I have a 2017 and have the ProComp 2.25" level. I ran it with the stock UCAs for about 20k miles without any issues. I got my 2017 in August of 2016 and none of the levels were offering replacement UCAs. I added cognito UCAs because I got them used for a good price. I'm not saying you wont have any issues but I'm not easy on my truck and the ball joints were fine when I took the stock UCAs out.
The ProComp kit is just a level and doesn't include a diff drop. It is the exact same kit as the Readylift 2.25" level just in a different box and costs less. Now Readylift is offering replacement UCAs with the kit. 7fdd87731ce40372b9d3b6d7ad7fbf8b.jpg
Sent from my SM-G950U using Tapatalk
I’ve got about 6k on my level, ordered Fox coilovers with resi’s, new Fabtech UCA’s and after lots of research, I cancelled my order and went with the 4.5” lift through CST Suspension. There are a few guys on the forum that got me turned on by it due to zero widening of the front wheel track unlike all the other brands and after many thousands of miles not one complaint. Leveling is fine for a clearing a bit larger tires but I noticed immediately after leveling with no larger tires that my truck rode rougher. This lift will put everything back but lift through spindles.
Sent from above
9 hours ago, rudyb said:
I dig it. Any rub with this setup? Are you running stock UCA? Is that a 1.5" level? Thanks
Thanks! Bilstein 5100's(front on 3rd setting, rear is stock height). Stock UCA's. Bilstein claims this is a 1.25" lift in the front, but I have a feeling it was just a bit more.
I did get some rubbing on the factory mudflaps so I took a dremel and trimmed the insides just a bit. No rubbing now.
Just 2” and 285s stock wheels. Nothing drastic
The interesting thing about people raving about leveling is they forget to mention from mid 2015 GM started using stamped steel UCA’s, causing your tires to rub onto your trucks frame and or UCA’s. Not trying to be negative about leveling but Doing a level, it caused me to spend thousands of dollars replacing stock wheels with new +1 offset and finally larger tires (no rubbing) at a cost of approximately $3K later. At least I’m half way done on what it costs to lift a truck lol!
This is only experienced with my 20” wheels and tires.
Also forgot to mention you’ll need new shocks too for the raised height preferably Bilstein 5100’s
Sent from above
Sent from above
I am in the same boat, I am currently looking into control arms or possibly doing the same CST lift too.  I don't want the headache down the road....
Not worth the headaches, believe me. So much BS going on these forums with lies how some aren’t getting any rubbing with exact setup only to admit it soon after as “its not bad” lmao! Just spoke with the shop, haven’t received it yet from CST. I’m looking at first part of next week for install, arg!
Sent from above
Sent from above
Can’t imagine I’ll rub with the 285s. 32.5x11.5 should clear with 2”. I’ll report this afternoon. As far as the shocks go I’ll let it ride. Had same setup on my 14 (with 285/55 ko2s) and never thought it rode bad.
Running a procomp lift will included diff drop which doesn’t need new UCA’s cause with a diff drop your UCA’s will be fine for a while.
You should look at CST suspension, much better quality and doesn’t make your track widen up front like it does with all those knuckle replacement kits such as BDS, ProComp. A couple guy on this forum brought it up and I jumped on it.
Sent from above
A diff drop and UCAs are not related. Diff drop will help your CV joints return to a more stock angle. It will do nothing in regards to the upper ball joint which is the weak point of the stamped steel arms.
Sent from above
I hear ya..........I currently have a 3" level and am looking at control arms + a diff drop.
can't wait to see pics once it's done.
Speaking of my experience, after my 2.25” level was installed, the installer showed me that my UCA’s were not flat anymore, arched. Levels kill UCA’s!
Sent from above
It depends on the components selected.
It’s entirely possible to level a truck with new UCA’s, on stock wheels with larger tires, and get great ride quality.
You might get slight rub with 285’s depending on tire choice.
I get very slight rubbing at full lock with my 285
Nitto Trail Grappler MT’s on stock wheels.
Right after I did my level I installed 275/60/20 KO2’s and they rubbed bad! Went to a Fuel+18 and still rubbed but not as bad, Only thing that worked is current setup +1 offset 20X9’s with Nitto Ridge Grapplers 285/60/20’s
Sent from above
Absolutely correct, the UCA’s play a big role in it.
Sent from above
My 275/60/20’s on stock 20’s rubbed bad and embarrassing especially in grocery store parking lots.
Leveling over 2.25” is a money pit.
Sent from above
    xdieselmechanic
    xdieselmechanic
  • Who's Online   4 Members, 0 Anonymous, 702 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
    • There's some truth to the above, but also, she's selling fullsize trucks and bread/butter CUV's like hotcakes, meanwhile, extracting GM's pickups from the deep discounting sales game.   GM's stock has held its own during her tenure, and the more recent buybacks are delivering cash back to investors and signal confidence in their direction forward. Even with the EV losses.   GM is an example of a modern publicly traded company. The #1 goal of any publicly traded company is to deliver the most value possible to shareholders. Despite being a car company, building the best car isn't GM's path to delivering maximum shareholder value.   McDonalds doesn't make the best burger, or the best coffee.   I've mentioned in another thread, I really don't / won't ever understand Cadillac or Buick in a modern context. Both brands are completely dead to me. I'll cede that the Escalade is a nice SUV, but the brand and nameplate mean nothing to me, and GM will never persuade me to pay north of $170k for a gussied-up Tahoe or Burb. Other people don't mind doing that and that's their purview.   The C8 shares absolutely nothing in common with any other current Chevrolet or Corvette on the market. Since its introduction 8 years ago, it's developed quite the following. It did what other Corvettes couldn't do: reduce the average age of its buyer. GM has something there, and I see them investing in the car. They'd better not mess that up.   We've successfully derailed Grumpy's thread again, but I think this one is meant to be more of a random thought thread so a little wandering is probably OK.
    • Sliding doors ftw   Also, Sienna ftw as well.  The in-laws got a 2024-2025 recently when their 2019 sienna was totaled due to a deer back in June.  They've been getting 38-40mpg on the 65mph highway they live on.
    • Forgot to mention that this started after changing the oil I use mobile 1 full syn with mobile one filter but I did add pro lube additive and was the first time doing so and is making me wonder just can't see why that would matter
