I was dead set on the readylift kit with new UCAs to level my 17, but now I'm starting to think that the Eibach Pro Truck kit might be a better option.  Anyone seen the two side by side?  Thinking that 275/65r20s or 285/60s.  Regardless, I think I'm settled on Ridge Grapplers.
2.25” front level, 1” added rear. Nitto Ridge Grapplers 285/60/20’s
Sent from above
Sent from above
Did you use the Readylift kit with new UCAs for the 2.25 up front?  What are the stats on the wheels?  Any rubbing?
I think I'm going to keep my stock rims for a while.
What year is your truck?
Sent from above
Just saw you’ve got a 17. You won’t be able to do a 275/60/20 and especially not the 285/60/20 with stock wheels on a level. Mine is the Billet Aluminum two pc strut level and added 1” onto the rear. I installed Fuel 20x9 +1 offset, no rubbing except for a pc of the felt liner that I heated up with a heat gun and now zero rubbing on anything.
Sent from above
Btw, by tomorrow night, I’m not going to be on a level, it’s going to be lifted with a CST 4.5” lift. Leveling didn’t give me the best ride quality even though I had Bilstein 5100’s all around.
Sent from above
Sent from above
There's 2 reasons why I can't wait for you to get this lift installed.
1. I want to see the pics. I've been considering this lift for awhile because I don't want my track width pushed out. Please post some pics from the side so we can see how it actually sits. Not the angle laying on the ground with the wheels flexed trying to make the lift look huge.
2. I'm wondering if CST is going to pay you for advertising with how much you've been posting about their lift lol. Are you going with the spacers or CSTs coil overs?
Sent from my SM-G950U using Tapatalk
  • Like 3
I haven’t made up my mind yet, it’s between Fox, CST, King. Either way, I’m going to wait 4-6 weeks for either of them cause my guy orders directly from the factory. I do not do any crazy off roading other than an occasional off the exit ramps or big speed bumps.
CST wasn’t even on my list of possible lifts cause everything widens your track and after being informed by a couple of members (19Trax95 which has the 4.5” lift and Ferraiolo1 which has the 6” lift) they’re the ones that deserve CST credit on these sites.
I started looking into it, calling multiple high end 4x4 shops, asking what’s the absolute best lift available, CST was the answer. Extremely well built and it’s all made in-house, made in America [emoji631]
I’m thinking it’s going to take a good day plus for install and tweaking and marking, alignment etc etc etc blah blah. I’ll definitely take pictures. I’m also contemplating whether or not to keep the same 285/60/20 Grapplers, not into the 35x12.50’s, I’m thinking possibly 285/65/20’s, have to wait and see what it’ll look like once lift is done.
Sent from above
New in regards to posting but have been a member sometime. I tried to go through most of the posts before asking questions but to be honest i cannot get a full answer so i'll ask.
I want to avoid any and all rubbing, so this is what i am thinking:
Motofab 3" front and 1" rear level
Cognito UCA
18x9 ET -12 Wheels
 285/65/18 tires or 295/65/18 depending on tire (again want to avoid rubbing)
At this point should i do coilovers? i don't plan on going any higher than 3".
I read a lot of posts about trying to stay away from 3" levels but i didn't read anything that's 100% convincing so anyone with REAL information please share.
Cognito UCA
18x9 ET -12 Wheels
Should have no rubbing i have 285/65r18 with 18x9 -12 on a 2.25 inch level and it only barely touches rarely ever. Cant even hear it rub u can just see the mark on the plastic once in a while
Sent from my SM-G950W using Tapatalk
Thanks for the information. This is good news, i guess i don't need to go with a 3" level in the front then. I wonder if i will clear a 295/60/18 with a 2.5 level in the front?
I don’t have time to read through everything, I need tires like now. My stock SRAs are slipping and sliding all over the place on wet roads. I want to upgrade tires and get a level. I’m looking at the rough country 2” lift. What is the biggest tire I can get on stock wheels? I have a ‘17 LTZ Z71 with 20” wheels. It will be a few months before I can upgrade those.
You’ve got stamped steel UCA’s and 20’s which means you’ll definitely get rubbing as soon as you add larger tires to your level. 275/60/20’s will rub on lock. Either you get same existing size new tires or you get new wheels with different offset to accommodate the +offset you’ve got with your factory wheels. I tried just with a level and new tires, rubbed to much, then I got new +1 offset wheels with new tires.
Sent from above
Should be good with the 285/55r20
Sent from above
What does +1 mean? I’m looking at tirebuyer.com and they list offsets as +18-31 and back spacing as 5.54-6.18. I know VW/Audi wheel fitment, this is my first time shopping for truck wheels.
YouTube it, that’s how I learned quickly, it’s from center of wheel, distance from hub which “plus” will either bring your wheel closer inside or “minus” which will push your wheel towards outside of fender. Typically 0 offset or +1 is the safe zone.
Sent from above
    nolankd
    nolankd
  • Who's Online   3 Members, 1 Anonymous, 460 Guests (See full list)
    • For a limited time, retail accounts receive a free fender cover (G2803) with their order of $750 or more when they use code FENDER926 at checkout. The promotion runs through Sept. 8, 2026. Own a business and want to apply for a retail account?  Apply here. https://www.amsoil.com/business-opportunities/sell-in-your-store/?zo=521390
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
