On 12/30/2016 at 5:49 PM, CHowell1991 said:
I got my 2015 leveled yesterday with 285/75r18s on stock wheels. 2.25" readylift. e9fb32455eb6e7a1ab4290d687ba3600.jpg4f06d63c867457887ff070665de117df.jpg
U have any rub or trim on that set up
Do they rub and any trim u had to do
On 11/15/2018 at 2:28 PM, TXGREEK said:
Everybody get ready!
Awesome Black Friday deals coming
Sent from above
I’m trying to take advantage of this, but can’t get ahold of CST via email, phone, or facebook messenger.  I’d like to get their front leveling coilovers and upper control arms, but don’t see any matching rear shocks on their site.  Does anyone know if they offer a basic Dirt Series 2.0 shock non-resi to replace my stock Ranchos?  Something exactly like the FOX 2.0 and Icon 2.0 non-resi shocks.
The closest part number I could find on their site is the CSR-5530 but that is listed for the new 2019s only.
On a side note, MRT and SDHQ have been very responsive to questions about other setups that I am pricing out.  Right now I am leaning towards the Icon stage 1 and will add their delta joint UCAs.
Edited by BbyDgital
They may be closed for the holidays, try them back on Monday. They do have the shocks you want.
The dealer had put on 22s.  I had them changed to 18s.  I also had Bilstein 5100s installed at the highest setting and also replaced the shocks in the back with Bilstein.  I love the stiffer ride.  I don't bounce all over the place now when I hit a bump.
Can anyone post a picture of what their ball joints look like with the 2in Rough Country leveling kit? I need to compare them to mine.
I'm sure this has been asked, but I'm lost and a little confused yet.
For my 2018 Sierra 1500, I am going to add GY DuraTracs, 275/60/20 (a 33" tire) and a 1.5"-2.0" front level kit (Rough Country).  Do I need to do anything with the UCA?
Not RC bit this is what mine looked like when I had the Readylift 2.25"
Sent from my SAMSUNG-SM-G890A using Tapatalk
Thanks, did you Readylift kit come with UCA's? I don't see the ball joint as crushed as with a Rough country 2in Kit.
Edited by Morenar
mispelling
It did not. This picture is with the stock stamped steel upper control arms.
On 9/12/2018 at 5:37 PM, SNAFU88 said:
Didn't care for the nose-high appearance of the truck with the 2" level so I installed the 2 inch rear block to give it a bit of rake again.  Subtle difference but just enough to fix the problem. Before and after:
80-_img_2218_e5853e5f6a94e36608f0f7f4897
80-_rearblock_624115fe5289acb3707d038cd4
I love your wheel and tire choice.  That looks great.  Very old school and cool. Any other pictures?
Thanks, man.  285/70-17s on 17x9 et -6 Pro Comps:
80-img_5404_4fab0d5fc7b42be38382f1088b05
80-img_5409_b6b3c15a4768edb60c3fd7e21127
Recently added a tool box:
80-img_0522_b7d7932291350f5e51f9f0d9783a
  • Like 3
I asked this question above, but I am also contemplating going 285/55/20 instead of the 60 tire to avoid any potential rubbing.  That tire is about a 32" tall tire, so only 1" taller than stock.
Would that 285/55 be a better option to avoid rubbing and potential UCA issues?  I really do not want to get into something and then have to throw a bunch more money trying to fix it because it was the wrong tire choice.
Edited by SouthpawHD
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
