1 hour ago, TXGREEK said:
I believe you have me mistaken with someone else
Dang it, yep, I was thinking of @SNAFU88 -lesson learned - don’t post while drinking at dinner.  LOL.
Dang it, yep, I was thinking of [mention=169808]SNAFU88[/mention] -lesson learned - don’t post while drinking at dinner.  LOL.
I’ve picked up on a whole lot of that going on, on these forums
On 11/29/2018 at 9:02 AM, SNAFU88 said:
Thanks, man.  285/70-17s on 17x9 et -6 Pro Comps:
80-img_5404_4fab0d5fc7b42be38382f1088b05
80-img_5409_b6b3c15a4768edb60c3fd7e21127
Recently added a tool box:
80-img_0522_b7d7932291350f5e51f9f0d9783a
Great pics!  I've always been a fan of white lettering on the tires.  This is definitely the route I will go if I buy black rims.  Still debating between black or bronze...
On 11/24/2018 at 9:35 PM, TXGREEK said:
They may be closed for the holidays, try them back on Monday. They do have the shocks you want.
Unfortunately, I have had no luck getting a hold of them.  Didn't feel comfortable placing an order with a company that was this hard to get a return message from.
I was also curious about the color scheme of their coilovers.  The pics that you posted of your set look like they are more of a gray color, but the pics on CST's site look like they they are black with silver coils.  I actually prefer the gray, so that was another question that I wanted to clarify with them.
Not sure if I’ve already posted the finished results here.
Yeah I really like the look of those front coilovers.  Hopefully I will be able to connect with them at some point.  Have a feeling they won’t honor their Black Friday pricing, but it never hurts to ask!
Well, I gave you the #, try it out. I know on weekends they’re on skeleton crew.
I think I’ve read all 457 pages of this forum and I just want to clarify something. If I get the ready lift 2.25 level WITH UCA’s I should be good to run 275/60r20 on stock wheels without rubbing correct?
2017 Silverado crew cab with stamped UCA’s currently.
Want to make sure I do this right and don’t go down a rabbit hole of lost money
Yes. I ran 275/60/20 KO2’s and they rubbed on stock wheels. With new UCA’s you should be good but call them and discuss it with them just to give yourself added security.
Just talked to them. No dice. Said the recommend a 1/2 inch spacer which I’m trying to avoid. Sounds like you can’t level these 2017’s and run a bigger tire on stock wheels with anything currently out there without another mod.
I had to buy new 20x9 wheels with a plus 1 offset which fixed the issue. You’ll also need to buy new rear shocks leveled or lifted. I ran Bilstein 5100’s.
This was the finished product 2.25” level with 285/60/20’s.
This is the current setup with a 4.5” CST lift and suspension. Rides just like stock, a ton better than the leveled setup I had. I will never level anything ever again without doing front coilovers.
Why do you need new rear shocks in the situation? It’s already 2-3 inches higher in back
That’s if you raise the rear as well when leveling.
Got it. Thanks for the info. Great looking truck btw.
Anyone know if I just put a 1.5 spacer with stock wheels and tires  if that will work out ok?
Im just trying to eliminate some of the extreme rake
Edited by SilveradoMikeB
    ncleg
    ncleg
  • Who's Online   3 Members, 0 Anonymous, 1,235 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
