Got it. Thanks for the info. Great looking truck btw.
Anyone know if I just put a 1.5 spacer with stock wheels and tires  if that will work out ok?
Im just trying to eliminate some of the extreme rake
You can do that and be just fine
Thanks
Thanks for all the help. Looks like I’ll get a minor front end level and stay with stock sizes tires. 95% of my driving is highway so not a big deal. Appreciate all the info everyone
That’s if you raise the rear as well when leveling.
You can add say an 1" to the rear and be totally fine on the factory shocks. If your going 2" or more you'd want to get the longer shocks but at that point your not leveling anything.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Adding 1” to your existing 1” makes it two, highly recommended to switch out rear shocks for having a 2” in the rear so you do not over extend the cheap factory shocks. Bilstein makes the 5100’s, a very good entry to medium level shock.
If you’re swapping the stock rear blocks (because you NEVER stack blocks) which are 1.25” for say a 2” block that’s only a net lift of .75”, for that you don’t NEED to replace the rear shocks. Once you start talking 3” (net gain of 1.75”) or bigger blocks, at that point you need to swap shocks
Adding a 1" taller block out back gives you 1" of lift over stock not 2". A 1" lift block is actually 2.25" tall if that's what your referring to but the OEM shocks are designed to work with the factory block. Sure it will ride nicer with Bilstein's but it is not neccessary for an inch. There was zero detectible ride change with a 1" taller block and reusing the factory shocks. I'm speaking from personal experience.
The Bilstein 5100’s are taller than stock shocks and that’s why they ride better than stock when you add to the rear block. My personal experience. I’ve only leveled one truck in my life and hated the ride quality.
I’d highly recommend anyone interested in leveling or lifting to consult an expert that does installs for a living as that’s who guided me to understand better fit and finish.
Or follow this simple guide:
- best ride quality & most expensive: coilovers
- cheapest: pick a spacer and throw it in, ride quality will not be as good as stock, but not unbearable
- budget: Bilsteins. They ride stiff, but the truck is more planted and takes bumps "better" (that's a very subjective statement)
- want a lift: CST, BDS, Or zone. Keep factory ride, or see coilovers section above
This will cover 98% of people on this forum. Do I install these for a living? No, but I do sit in front of a computer all day and have done more research on these trucks than I probably should have [emoji3]
That about sums it up 100%. Leveling and lifts are pretty basic stuff lol
You get what you pay for, Bilsteins are a great entry and way better than stock, stiffer. I’ll never use Bilsteins ever again after my CST lift and CST Coilovers with rear resi’s. Again, anyone can get the look, you get what you pay for.
My post outlines this exactly. For some, Bilsteins are perfect, for others (you and others I've heard from) they're not, which is why it's subjective.
That being said, not everyone has $3k+ to drop on a lift kit and coilovers like you did. I agree that your setup is the best of the best, but not everyone desires to spend that much on their truck just for the lift kit. Which is where the Bilsteins come in
And just to muddy the waters for ya...not all coilovers (or shocks for that matter) are created equal.
And, depending on who did the valving, you could have a good setup, or a crappy setup, even with the same brand and part numbers.
A King or Fox sticker on a piece of car jewelry isn’t a guarantee of anything.
I'm no expert but I have owned several lifted and leveled trucks. That being said I just don't want to spread misinformation about what is "needed" or what is merely an opinion about ride quality.
And, depending on who did the valving, you could have a good setup, or a crappy setup, even with the same brand and pet numbers.
That’s absolutely correct, to each their own. My experience is you get what you pay for. Anyone can get a lift but save up and get the best cause the look matters nothing as well as big shiny wheels. Ride quality is second to none with high quality parts.
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 295 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
