I have a 2017 and have the ProComp 2.25" level. I ran it with the stock UCAs for about 20k miles without any issues. I got my 2017 in August of 2016 and none of the levels were offering replacement UCAs. I added cognito UCAs because I got them used for a good price. I'm not saying you wont have any issues but I'm not easy on my truck and the ball joints were fine when I took the stock UCAs out.
The ProComp kit is just a level and doesn't include a diff drop. It is the exact same kit as the Readylift 2.25" level just in a different box and costs less. Now Readylift is offering replacement UCAs with the kit. 7fdd87731ce40372b9d3b6d7ad7fbf8b.jpg
Sent from my SM-G950U using Tapatalk
I’ve got about 6k on my level, ordered Fox coilovers with resi’s, new Fabtech UCA’s and after lots of research, I cancelled my order and went with the 4.5” lift through CST Suspension. There are a few guys on the forum that got me turned on by it due to zero widening of the front wheel track unlike all the other brands and after many thousands of miles not one complaint. Leveling is fine for a clearing a bit larger tires but I noticed immediately after leveling with no larger tires that my truck rode rougher. This lift will put everything back but lift through spindles.
Sent from above
9 hours ago, rudyb said:
I dig it. Any rub with this setup? Are you running stock UCA? Is that a 1.5" level? Thanks
Thanks! Bilstein 5100's(front on 3rd setting, rear is stock height). Stock UCA's. Bilstein claims this is a 1.25" lift in the front, but I have a feeling it was just a bit more.
I did get some rubbing on the factory mudflaps so I took a dremel and trimmed the insides just a bit. No rubbing now.
Just 2” and 285s stock wheels. Nothing drastic
The interesting thing about people raving about leveling is they forget to mention from mid 2015 GM started using stamped steel UCA’s, causing your tires to rub onto your trucks frame and or UCA’s. Not trying to be negative about leveling but Doing a level, it caused me to spend thousands of dollars replacing stock wheels with new +1 offset and finally larger tires (no rubbing) at a cost of approximately $3K later. At least I’m half way done on what it costs to lift a truck lol!
This is only experienced with my 20” wheels and tires.
Also forgot to mention you’ll need new shocks too for the raised height preferably Bilstein 5100’s
Sent from above
Sent from above
I am in the same boat, I am currently looking into control arms or possibly doing the same CST lift too.  I don't want the headache down the road....
Not worth the headaches, believe me. So much BS going on these forums with lies how some aren’t getting any rubbing with exact setup only to admit it soon after as “its not bad” lmao! Just spoke with the shop, haven’t received it yet from CST. I’m looking at first part of next week for install, arg!
Sent from above
Sent from above
Can’t imagine I’ll rub with the 285s. 32.5x11.5 should clear with 2”. I’ll report this afternoon. As far as the shocks go I’ll let it ride. Had same setup on my 14 (with 285/55 ko2s) and never thought it rode bad.
Running a procomp lift will included diff drop which doesn’t need new UCA’s cause with a diff drop your UCA’s will be fine for a while.
You should look at CST suspension, much better quality and doesn’t make your track widen up front like it does with all those knuckle replacement kits such as BDS, ProComp. A couple guy on this forum brought it up and I jumped on it.
Sent from above
A diff drop and UCAs are not related. Diff drop will help your CV joints return to a more stock angle. It will do nothing in regards to the upper ball joint which is the weak point of the stamped steel arms.
Sent from above
I hear ya..........I currently have a 3" level and am looking at control arms + a diff drop.
can't wait to see pics once it's done.
Speaking of my experience, after my 2.25” level was installed, the installer showed me that my UCA’s were not flat anymore, arched. Levels kill UCA’s!
Sent from above
It depends on the components selected.
It’s entirely possible to level a truck with new UCA’s, on stock wheels with larger tires, and get great ride quality.
You might get slight rub with 285’s depending on tire choice.
I get very slight rubbing at full lock with my 285
Nitto Trail Grappler MT’s on stock wheels.
Right after I did my level I installed 275/60/20 KO2’s and they rubbed bad! Went to a Fuel+18 and still rubbed but not as bad, Only thing that worked is current setup +1 offset 20X9’s with Nitto Ridge Grapplers 285/60/20’s
Sent from above
Absolutely correct, the UCA’s play a big role in it.
Sent from above
My 275/60/20’s on stock 20’s rubbed bad and embarrassing especially in grocery store parking lots.
Leveling over 2.25” is a money pit.
Sent from above
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
    • Sounds like maybe it's announcing Navigation turns or Alerts (it mutes the music) ? When it mutes again, turn up the volume quickly and see if maybe the navigation volume is really low?
