ducklawyer Posted November 5, 2018 Posted November 5, 2018 No rubbing on normal driving as of yet (have not had any chance for articulation). Pleased with size of 285sSent from my iPhone using Tapatalk
TXGREEK Posted November 5, 2018 Posted November 5, 2018 No rubbing on normal driving as of yet (have not had any chance for articulation). Pleased with size of 285sSent from my iPhone using Tapatalk Very [emoji106][emoji2532] Sent from above
mrskiff Posted November 5, 2018 Posted November 5, 2018 No rubbing on normal driving as of yet (have not had any chance for articulation). Pleased with size of 285sSent from my iPhone using Tapatalk You shouldnt rub ever. I have k02s in 285/65 as well on a 2.25 level with -12 offset wheels and i hardly ever rub. Sent from my SM-G950W using Tapatalk 1
TXGREEK Posted November 5, 2018 Posted November 5, 2018 You shouldnt rub ever. I have k02s in 285/65 as well on a 2.25 level with -12 offset wheels and i hardly ever rub. Sent from my SM-G950W using TapatalkYou’re not running stock wheels you’re running a -12 wheel and barely rubs, meaning it’s rubbing nonetheless. I think most rubbing is on 20”. My rubbing happened while locking on a full turn or while backing up. Sent from above
18SierraAT Posted November 6, 2018 Posted November 6, 2018 Im thinking of going with the RL 2.5 up front and the Motofab 2in block in the rear. The RL comes with new UCA's. Im planning on putting a 1.25" spacer on the stock AT wheels and then adding 33x12.50 tires. Will I need a dif drop with a 2.5 in lift? Also Ive read about 75 pages from this thread and there seems to be no clear answer...do I need new UCA's with a 2.5 upfront? From what ive read some people say yes and you shouldnt do it without it and others say its not necessary.
frenchsquared Posted November 8, 2018 Posted November 8, 2018 On 11/4/2018 at 8:01 PM, StayInYourLayne said: For those of you who have a 2017+ and installed 2.25" level without changing the UCAs, have you had any issues. Dealer is offering to install a ProComp kit without UCAs and keep my warranty in tact but I don't want to make the truck unsafe even if they keep the warranty. What good is a warranty if the truck is totaled? I put 40,000 on a 2015 in 2014 before all this complaining about upper control arms. Never had any issues at all.
StayInYourLayne Posted November 8, 2018 Posted November 8, 2018 I put 40,000 on a 2015 in 2014 before all this complaining about upper control arms. Never had any issues at all. 2014s, 2015s and early 2016s had different control arms than the late 2016s-2018s. I had a '14 leveled with spacers and no issues but the new control arms are said to have issues with levels
2018Chevyz71 Posted November 11, 2018 Posted November 11, 2018 (edited) Installed Motofad 1.5” leveling kit today. In my opinion this is how the truck should have shipped from the factory. Ground to bottom of from fender before level, measured 36.5” after 38”. Rear measures 39” so I have 1” of rake which is just right for the truck to sit level with a load in the bed. I was able to install the spacer blocks by just removing the sway bar links, and loosening the nuts on the top of the strut. I did not need to remove the tie rod or spindle from the upper control arms. Total project took just over an hour in the drive way all with hand tools. I debated between going with 1”/1.5”/2” and I think the 1.5” was the right choice for the look that I was going for. Before and after pics of truck and CV angles. Edited November 11, 2018 by 2018Chevyz71 1
TXGREEK Posted November 11, 2018 Posted November 11, 2018 2014s, 2015s and early 2016s had different control arms than the late 2016s-2018s. I had a '14 leveled with spacers and no issues but the new control arms are said to have issues with levels Correct except they started with the stamped steel in some cases early 2015 causing issues almost immediately once you level. I’ve got the 18, leveled with a 2.25” up front and added a 1” onto the rear, had to buy new wheels in order to run larger tires. In a few days it’s all coming out, going with CST 4.5” lift, absolutely amazing quality lift that doesn’t widen your track once lifted. Check them out https://cstsuspension.com/content/10-media-articlesSent from above
harrisonhunter Posted November 11, 2018 Posted November 11, 2018 I have an 18 with 1.75" proryde lift up front. 275/60/20 Durateacs on stocks and it rubs at full lock.Sent from my SAMSUNG-SM-G930A using Tapatalk 1
TXGREEK Posted November 11, 2018 Posted November 11, 2018 I have an 18 with 1.75" proryde lift up front. 275/60/20 Durateacs on stocks and it rubs at full lock.Sent from my SAMSUNG-SM-G930A using Tapatalk Exactly what happened to me, installed new wheels with a +1 offset, fixed that issue immediately. Nitto Ridge Grapplers 285/60/20’s Sent from above
harrisonhunter Posted November 11, 2018 Posted November 11, 2018 It rubs very minor so I'm not extremely concerned about itSent from my SAMSUNG-SM-G930A using Tapatalk
Shredder15 Posted November 11, 2018 Posted November 11, 2018 19 hours ago, 2018Chevyz71 said: Installed Motofad 1.5” leveling kit today. In my opinion this is how the truck should have shipped from the factory. Ground to bottom of from fender before level, measured 36.5” after 38”. Rear measures 39” so I have 1” of rake which is just right for the truck to sit level with a load in the bed. I was able to install the spacer blocks by just removing the sway bar links, and loosening the nuts on the top of the strut. I did not need to remove the tie rod or spindle from the upper control arms. Total project took just over an hour in the drive way all with hand tools. I debated between going with 1”/1.5”/2” and I think the 1.5” was the right choice for the look that I was going for. Before and after pics of truck and CV angles. Agree it should come that way. I worked to find the best combo Of above factory while keeping factory ride. Accomplished both with 2” under strut only TGC level kit and 2.25” block in the rear. Love the slight height difference from stock.
TXGREEK Posted November 11, 2018 Posted November 11, 2018 It rubs very minor so I'm not extremely concerned about itSent from my SAMSUNG-SM-G930A using TapatalkUnlike me, with my OCD, I can’t stand having any rubbing, just makes it feel cheap to me. Sent from above
RHStansbury Posted November 11, 2018 Posted November 11, 2018 I was dead set on the readylift kit with new UCAs to level my 17, but now I'm starting to think that the Eibach Pro Truck kit might be a better option. Anyone seen the two side by side? Thinking that 275/65r20s or 285/60s. Regardless, I think I'm settled on Ridge Grapplers.
