1 hour ago, TXGREEK said:
I believe you have me mistaken with someone else
Dang it, yep, I was thinking of @SNAFU88 -lesson learned - don’t post while drinking at dinner.  LOL.
Dang it, yep, I was thinking of [mention=169808]SNAFU88[/mention] -lesson learned - don’t post while drinking at dinner.  LOL.
I’ve picked up on a whole lot of that going on, on these forums
On 11/29/2018 at 9:02 AM, SNAFU88 said:
Thanks, man.  285/70-17s on 17x9 et -6 Pro Comps:
80-img_5404_4fab0d5fc7b42be38382f1088b05
80-img_5409_b6b3c15a4768edb60c3fd7e21127
Recently added a tool box:
80-img_0522_b7d7932291350f5e51f9f0d9783a
Great pics!  I've always been a fan of white lettering on the tires.  This is definitely the route I will go if I buy black rims.  Still debating between black or bronze...
On 11/24/2018 at 9:35 PM, TXGREEK said:
They may be closed for the holidays, try them back on Monday. They do have the shocks you want.
Unfortunately, I have had no luck getting a hold of them.  Didn't feel comfortable placing an order with a company that was this hard to get a return message from.
I was also curious about the color scheme of their coilovers.  The pics that you posted of your set look like they are more of a gray color, but the pics on CST's site look like they they are black with silver coils.  I actually prefer the gray, so that was another question that I wanted to clarify with them.
Not sure if I’ve already posted the finished results here.
Yeah I really like the look of those front coilovers.  Hopefully I will be able to connect with them at some point.  Have a feeling they won’t honor their Black Friday pricing, but it never hurts to ask!
Well, I gave you the #, try it out. I know on weekends they’re on skeleton crew.
I think I’ve read all 457 pages of this forum and I just want to clarify something. If I get the ready lift 2.25 level WITH UCA’s I should be good to run 275/60r20 on stock wheels without rubbing correct?
2017 Silverado crew cab with stamped UCA’s currently.
Want to make sure I do this right and don’t go down a rabbit hole of lost money
Yes. I ran 275/60/20 KO2’s and they rubbed on stock wheels. With new UCA’s you should be good but call them and discuss it with them just to give yourself added security.
Just talked to them. No dice. Said the recommend a 1/2 inch spacer which I’m trying to avoid. Sounds like you can’t level these 2017’s and run a bigger tire on stock wheels with anything currently out there without another mod.
I had to buy new 20x9 wheels with a plus 1 offset which fixed the issue. You’ll also need to buy new rear shocks leveled or lifted. I ran Bilstein 5100’s.
This was the finished product 2.25” level with 285/60/20’s.
This is the current setup with a 4.5” CST lift and suspension. Rides just like stock, a ton better than the leveled setup I had. I will never level anything ever again without doing front coilovers.
Why do you need new rear shocks in the situation? It’s already 2-3 inches higher in back
That’s if you raise the rear as well when leveling.
Got it. Thanks for the info. Great looking truck btw.
Anyone know if I just put a 1.5 spacer with stock wheels and tires  if that will work out ok?
Im just trying to eliminate some of the extreme rake
Edited by SilveradoMikeB
    • Big oil is raking in billions from the Iran war. Can it avoid Trump’s fury?   Remember I said Big Oil is 'Vertically Integrated"?   Even as they no longer own the majority of the "Pump" they still own the "Well". Crude price upward pressure does not translate into that same pressure on production. Pumping cost remain unaffected and the gap is pure profit. Even after subtraction of a minor, comparatively, lower amount from supposed, but not always, realized refining volume. Consumers hate war, Big Oil, not so much.
    • We live in a world where the average person expects more. People say wages and our needs are farther apart. My first new home had 3 bedrooms and one bedroom. My first car and truck had what would be considered a stripped or work vehicle. In my neighborhood back then there were more homes like that and cars too. Middle managers and second home buyers worked their way up to the fancy houses and cars. Car loans were 3 years. GM had different models of cars for different income levels. The cars were pretty much the same size if you wanted a big vehicle. The nameplate designated the opulence. Chevy, Pontiac, Buick, Oldsmobile and Cadillac.  To be fair some of the cost is government mandated. We can’t blame them for giving us what people will pay for. Careful advertising steering people towards more profitable SUVs and trucks. As I learned recently a minivan is a cheaper more efficient form of transportation. Certainly easier to live with. Somebody realized the profit margin wasn’t as big and gave it a soccer mom label. So it lost its coolness. They’re making it the masses are buying it. You hit your hand with a hammer you can’t blame the hammer.
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  The Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
