1 hour ago, LRMRZ said:
I was looking at images on google when I came across this picture. I clicked on the link and it sent me over to Pinterest lol the description on the pic says that it has a 3 inch motofab level kit and 33 inch tires with method wheels.
I have a 3" level on mine with Cognito upper control arms.  My tire size is 285/65/18, roughly a 33'' tire....I've had zero issues.  I am planning on changing out the level with the King 2.5 Coilovers very soon.
Bronze.thumb.jpg.d96a9b5c0297fae95dd3c766dbd41858.jpg5c82ef157b756_Bronze2.thumb.png.028d9751c1fffcf36b180907e6ee04a8.png
Changed my setup a bit.
Motofab 2.5" up front
Motofab 2.25" blocks in rear
Readylift UCA's
305/65r18 BFG KO2's
18x9 -12 Black Iron Wheels
Zone fender trim plates to fit the tires. Fenders measure 40.5" up front and 41.5" in rear. Need to wash truck and get some better pictures.430db37d067c71dbcaf89b385e1921cd.jpgebf0e3caffe942d13affc36ffff84ce8.jpg
Sent from my SM-G950W using Tapatalk
Readylift UCA's
305/65r18 BFG KO2's
Did you do the zone trim plates yourself?
Nope the shop did it. There is a good video on YouTube that shows how its done.
Finally got my baja kits on after waiting several months. Upper and lower control arms, modified and revalved the king shocks for much better rebound and removed a limiter spacer so the shock uses all of its droop travel. This thing now rides on a cloud! beb27fe72103368ef8870a882b134ea3.jpg2678e3acea3d0ef64e521bcd23973628.jpg139ac07d404c79e295a2e4f84f64a203.jpg51b6bbebd31460101817bbdef8edaaa3.jpg
What size tires and wheels are those? Looks sharp!
Just installed a 2.5” RC leveling kit and put on K02 275/65R20s. Happy with the finished product, just need to trim a little felt that is rubbing.
I have an 18 1500 that has 2.25 inch level in the front and I’m going to put a 2”block in the back. Thinking about going to 17 or 18 inch wheels (running 20’s now)- I just like more tire than wheel- what offset should I look at to keep them tucked and not so wide? Also could I run a 34 or 35 inch tire?
Hello all!
First of all, thanks to all of you who contribute to this site.  It is great!
I've read through this thread and I am left with a few specific questions regarding my 2018 Z71 (stamped steel UCA's).
  1. If I go with the TGC 2" leveling kit, do I still need to swap out my UCA's?  (my backup plan is the 2.25 Readylift kit with UCA's)
  2. Assuming the TGC 2" kit is "safe" for my 2018 stamped steel UCA's, can I fit 285/65/r18 BFG KO2's on my stock wheels without any rubbing (I have seen several different opinions about this setup).  I'm hoping that the narrow section width BFG's will not rub my UCA's or sway bar.  I'm aware that I'll have to tie back the felt, etc.
  3. What size KO2 will fit on my bone stock truck if I tie back the felt and decide to leave the suspension alone?
Thanks in advance!
Regards,
RCD
On 2/12/2019 at 11:49 AM, Scooter Scott said:
So after a 2" level and ReadyLift control arms, I do get a very slight rub on the upper control arms.  Has anyone extended the steering stops to keep from full lock hitting the arm?  It would not be that much so I don't think it would be that much of a problem for the turning radius.
Scott, what did you end up doing here? I just installed 275/65/20 K02s with a 2.5" RC lift w/ the 2" rear block. Definitely rubbing the UCAs as well when initially i thought it was just the felt. Trying to decide what to do now...
On 2/12/2019 at 12:19 PM, wepiii said:
Are you 100% it’s the UCA’s. I was positive that is what mine was rubbing, but it was actually hitting the sway bar. Most noticeable hard right going forward. I have 275-60/20’s and I scrub the sway bar, I’m not sure how you wouldn’t with an even taller tire. Mine is a 2018 as well so same UCA set up
Wepii, are yours still hitting the sway bar or did you change your setup?
Still hitting if I pull as hard as I can on steering wheel, I just try not to do that and I’m good
Was curious if someone could point me in the direction of some 1.5 inch rear blocks that are not tapered. Would like a pinch of rake after the level
After reading everything I could find, I finally made a decision.  I chose 285/60/18 BFGoodrich KO2's, no lift, no leveling, stock everything.
Thanks to all who have contributed to this thread.  It was nice to see what others have done with their trucks.  I've had my share of lifted trucks (some of them crazy high like 12" on 40's)...I'm enjoying this one a bit closer to the ground.
The ride and handling are much better...especially the handling.  I'm impressed with the KO2s.
  • Like 5
Very nice!
Do you think with new control arms they would fit without rubbing? Thinking about going this same route with my setup except some readylift control arms
    C. Hart
    C. Hart
  • Who's Online   2 Members, 0 Anonymous, 458 Guests (See full list)
