14 hours ago, acinquegrana said:
Pinion angles don't "seat themselves".
You beat me to it, I was going to say the same thing.  How does a pinion angle seat itself?  :shakehead:
Well I finally got to a point in my schedule to take a picture of the rear blocks but I can’t get it to upload. No matter, they were used two inch blocks that were not tapered at all. I took them out and reinstalled the stock blocks for now. I have ordered the two inch blocks from RC and will install them as soon as I can. The vibration seems to be gone I believe. I haven’t really driven the truck much since I just did the swap today. I will post again later in the week to update. Thanks for all the helpful comments.
On 1/24/2019 at 11:16 AM, SSMUFF said:
Nice truck (twin).  You say you did the 2" up front only but in your signature you mention the 2.5.  Did you do the full RC 2.5 kit or did you do just the less expensive option and lift the front only?
just the front only
Reporting back that after shocks settled I have a slight rub with 295/70r17 Toyo rt’s and method 17x8.5 with a 0 offset. Shocks were set for 2.5” of lift. The rub is very minor and only at full lock in either direction. The rub is only on the felt liner and could easily be fixed with zip ties.
No. Coil overs are adjustable in place. The quicklift is just an extended strut. And IMO they ride like shit.
Ahh ok I gotcha but is it a better ride than spacers?
There’s nothing better riding than coilovers
Sent from above
I found the quicklifts to be about the same as the spacers when I did the swap in my 2012. On my 2014 I went to bilstein and found the ride to be better. On the 2014 I did the bilstein 5100's set at 1.85" with a 1/4" spacer, and I found the ride to be pretty much the same as stock.
Sent from above
Not doubting that but the CST coilovers cost 1200$ thats a little much
I know you’re not. You get what you pay for. You can get a set of Fox 2.0 setting to 2” max, approximately $900. Pop out your whole stock setup, put them in storage and enjoy your new Fox Coilovers. Bilstein adjustable front struts are the cheapest route but not as smooth as coilovers.
If you’re in a hurry and don’t want to save up then the Bilsteins is your comfortable cheapest route or save a few extra hundred and have the coilovers.
Sent from above
For those that are tracking my vibration situation. The vibration didn’t go away after removing the rear blocks and restoring the rear to stock. I plan on removing the 2.5 inch kit from the front now to see if it returns to normal. If that doesn’t work then I will take it to the dealership that I bought the truck and hope whatever is wrong will be covered by warranty. My truck doesn’t even have 5 thousand miles yet. I am now sorry that I ever messed with it. Just wanted it to set level and be able to fit a little larger tire.
did you get a front end alignment when  you lifted it?
On 1/31/2019 at 10:57 PM, Slick66 said:
Yes I had the same shop that did the install do the alignment.
When the shop did your leveling kit, did you have a 1" diff drop added as well? If not, the CV's are probably causing the vib. Simple install, takes about an 1.5hr my yourself and that well get you back close to factory angles while still maintaining the leveling kit. The diff drop spacer kits run about $40.  Just my 2 cents.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,201 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
