On 2/3/2019 at 11:06 AM, Chasenfins said:
When the shop did your leveling kit, did you have a 1" diff drop added as well? If not, the CV's are probably causing the vib. Simple install, takes about an 1.5hr my yourself and that well get you back close to factory angles while still maintaining the leveling kit. The diff drop spacer kits run about $40.  Just my 2 cents.
It is recommended to install a diff drop when installing a 2" under-strut (Motofab) leveling block?
No it's not recommended when doing just a 2" level. A 2" under strut level is just a 1" spacer between  the lca and strut. A diff drop would be a good idea if your going over a 2 1/2" level, but I would advise against anything over a 2 1/2" level.
I just ordered readylift UCAs and 2" spacer level.  I'm taking a shot that I can do this an keep my stock wheels.  Hopefully it works
Please update, I’m thinking of going the same route. Are you running factory 20’s? And if so what tire size
275/65/20 on stock 20s.  As of right now the only rub that I had was on the inner liner...which I have ziptied out of the way.
Thank you! Do you have the aluminum control arms or stamped steel? What size level? Also, any way you could post a picture?
I’m not sure why so many are against that extra 0.5” in going with a 3” level. I’ve seen guys say they’ve had no issues and some say they’ve “heard” horror stories. I wonder how much of this is first hand experience and how much is just people repeating what the internet experts or local tire shops are saying. My CV angles are at 11 degrees with a Crown Suspension 3” top mount spacer. No vibrations, no noises, etc. I plan on upgrading to some coilovers and adding a diff drop but I’m happy with it for now. I have RC Forged uppers and honestly this thing doesn’t ride any worse than stock. I’ve ran 2”, 2.5” kits and Bilsteins on previous trucks and really couldn’t tell a drastic difference in ride quality for any of the set ups. Regardless of what you go with, get an alignment once installed and regularly check your front end.
Yes I know the Cali lean is not a popular look around here. I’m running 315/70/17 KO2s. My front fenders are just shy of 41”
This is a Mcgaughys lift. Not sure what it is set to but my angles aren’t this bad. I know there are better lifts out there that give nearly stock angles but thought this was interesting being a “real” suspension lift.
Definitely rubs the UCAs....damn.
Now to decide how to remediate it...
Mind putting up a pic of how much you trimmed to get those tires to fit in there?
your sig says 2" level and 1.5" BL. Did you keep the BL on? If you did then that means you have 4.5" of lift in the front to clear those 35s, correct?
Sig is from a previous truck. I don’t even see it using Tapatalk.
  I originally trimmed the plastic protectors and massaged the fenders back. I ended up doing the Zone trim plates to get a little more clearance. I think I could put new plastic protectors on and it would clear now. Only rub is at full lock in reverse on the carpet liner.
db25c28cb6110f0151d5a2369776dae3.jpgb0c4fc6fb4095b787846841300cb02c2.jpg5c3d292dc42ad4e7bf88eebab276da6e.jpg
That looks like pretty minimal cutting, I like it. What are the zone trim plates? Never heard of those
    • I only have a few of the ACDelco blue remaining. One or two of the (old, old) ACDelco Professional boxes, and a couple of the newer style GM boxes with the simulcast in Chinese along with English. FWIW they've all been pretty good, regardless of where they are made, and in 20 years I've never had a problem with an e-core filter.   Now I have a couple of the "A" series in my home inventory. They come in a plain white box with the GM hologram sticker and model information. Have not installed one yet, want to use up my oldest inventory first.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
