2016 4wd, added motofab 1.5". I have parts to add 1" in rear, gonna hold off on that for now. Will wait and see what it looks like when I start towing a little more often.
Will keep stock tires a little longer, then race with 275/60/20 Cooper all terrains.
Sent from my SM-G930T using Tapatalk
Has anyone ordered from mrtmotorsports on here. I ordered an eibach pro truck kit and havent heard anything from them. My order is there on the internet but cannot get a response from them.
I was quoted 400 bucks to level my truck. includes rough country 2 inch leveling kit, labor and alignment. Does that sound reasonable? I think i want the maxx suspension kit though.
Sent from my SM-G955U1 using Tapatalk
2 minutes ago, Jusaplaya said:
2015 Chevy Silverado 2.5 Motofab level and Toyo Mt 295/70R18 tires.  Got the truck back friday.
I got the motofab 3" motofab and got 285 75 18 (35")
On 12/30/2016 at 5:49 PM, CHowell1991 said:
I got my 2015 leveled yesterday with 285/75r18s on stock wheels. 2.25" readylift. e9fb32455eb6e7a1ab4290d687ba3600.jpg4f06d63c867457887ff070665de117df.jpg
Do u have any problems at full lock?  My upper control arm is hitting something I don't know what. I think I need some wheel spacers to take care of that problem. I think I have a +30 range offset...........thanx
I am only hitting the carpet on both sides at full lock.  I need to cut it.  That is what the guy who installed it said.  I don't think I have any problems with control arms hitting.  I only have about 150 miles on it and haven't scrubbed.  I haven't really needed to lock the wheels.  I had 63k on my factory tires.  They were shot.  These tires seem to ride really good.  I wish I would have did this sooner.
Just bought this 2018 and put 2" front Motofab lower spacer.
Tires are 275/60/R20 (33")
Love the new look.  Not sure on what to do with the air dam yet.
All I had to do is just zipped tie the liner at the bottom...i have borla 2" wheel spacers and it made it worse rubbing on the cab corner. But when the 285 75 on truck wears down im putting those wheel spacers on and then I be drooping to 33" tire
Take it off it will look soooooo much better. I took my off?
Might be a bit on the high side.  Figure the keys are roughly $100, add $75 for the alignment and an hour labor of $100 or so.
Did you get an alignment? What was the total cost?
Did the work myself, $30 for the kit, $80 for alignment.  Toe needs to be adjusted after lift for sure.  My castor and camber were still good.  Took me about 3-4 hours, most of that trying to get the upper ball joint to let go.
navyguy357
Yes u need an alignment ever time u do work to suspension when they did my it was like 60-70$ can't remember
navyguy357
what is better, 2" level or 5100 shocks?
I just have a motofab 3" strut spacer and then 2" rear block on my truck
    smandy
    smandy
  • Who's Online   2 Members, 0 Anonymous, 536 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
