Idk why the pictures flip but that’s where I cut. Today I rubbed a little while backing out of my driveway and turning the whee all the way. I’m sure if I cut the felt up a little higher I would rub but I’m not. I spray painted the metal tab I cut and hit the edges up.
How tall are the back tires from ground to top of the tread when on the truck?
I’m gonna say about 33.5 inches
I want a lift...…….but it sounds like 2.5" is the max these trucks should have, before doing a full bracket lift?
I am thinking about a 2.5" front leveling kit, using the stock struts
1/2" bottom strut spacer and a 2" top spacer or a 2" bottom strut spacer and 1/2" top spacer? Which would be better and why?
Then, I would remove the stock rear block (1-1/4") and installing a 2" or 2.5" tall rear block
The cap and gear sagged the rear end almost 3/4"...………..so I am leaning towards the 2.5" rear block
I like my 18" wheels and want to try to keep them, just add larger tires
Just do a 2.5” top spacer. No point in splitting it between top and bottom
What I have on my truck
https://www.roughcountry.com/gm-leveling-lift-kit-1305-10.html
looks a bit familiar...I only added  a RC 2" level and 285/65R18 KO2s on my stock rims... I'm please with the stance...
post-162426-0-99530500-1503328109_thumb.jpg5b1e6d734ec86_truck1.thumb.jpg.8ea1c2e9459482fe32ec29511d267278.jpg
Edited by spenpet
How much room do you have with the 285/65R18?
275/70R18 : 33.20" x 10.80" (1.6" taller and .40" wider than stock
Not much of a increase over stock......I know I could fit a 275 series easy, but also like the wider tread
285/65R18 : 32.60" x 11.20" (1" taller and 0.8" wider than stock)
285/70R18 : 33.70" x 11.20" (2.1" taller and 0.8" wider than stock)
285/75R18 : 34.80" x 11.20" (3.2" taller and 0.8" wider than stock)
Went with the pro comp pro runner shocks, front is leveled just under 1.8”.
Did you have to trim any metal to fit those tires?
Nope just had to do the normal trimming on the plastic. I bought some trim plates just in case, but I didn’t have to use them.
Great thanks! Do you have any pictures of what you trimmed? I want to do the same setup
Not the cleanest trim, I used a dremel tool.
Quick question, I searched for hours with not too much conclusive luck...
Will aftermarket control arms such as Readylift work for a 2017 Denali with magneride? I have a 2.5 inch level kit waiting to go on but want to replace the stamped steel control arms as well to be safe.
2.25 Ready Lift
Zone add a leaf
285/60r20 Norcal Mod No Rubf1af57ab65756cf07d6475246bf15f22.jpgd805de75c0f2e7e4f1866c78e73db6a1.jpg
    C. Hart
    C. Hart
  • Who's Online   4 Members, 1 Anonymous, 621 Guests (See full list)
