I have a 2016 silverado 1500 4x4 Z71 Crew Cab 5.3 with a lift/level kit, 2.75" block on struts up front and added leaf spring in the rear. Also has an aftermarket front bumper (not sure if that matter much for clearance issues as it seems most issues occur on the cab side of the fender) current tires are 285/65r18 Kelly Safari TSRs. Due for a new set of shoes here soon and I'm curious if I would be able to clear a 295/70r18 Cooper Evolution A/T..specs on the Coopers say it is a 12.0" wide and 34.3" tall tire. I would be adding 2" KSP Hubcentric wheel spacers on my stock 18s. Thanks in advance for any help! Looking to order new tires within the next 2 weeks here.
https://photos.google.com/photo/AF1QipPg5j2OoZvI9TsT7rXTzGhS-WB-_SehFNB-SC17
https://photos.google.com/photo/AF1QipP5aumkLVL3ahqFSDY76mRE4KpnT_7KbAk2f01H
https://photos.google.com/photo/AF1QipMPsdsLkgU9AENV4oIzVqKC2JS6NFkLk86v4rYw
Sometimes in life - you just gotta send it.....
2015 Chevy Silverado 1500 5.3L V8 Z71 with newly installed Toyo Open Country AT3 35x11.5r20s on just a 2.5" RC Level.  Yea I said it - just the level - no RUB.  And no difference in ride quality on highway or just intermediate roads.  AT3s run smooth and are way quieter than Ridge Grapplers.
On 2/5/2022 at 4:24 PM, Jake2017AT said:
Figured I’d share. 2.5” Rough Country level and 285/60/20 Toyo AT3’s. Love this look!B67A4FB4-027B-49C7-BA80-B95F21DD96C8.thumb.jpeg.454d046a3cd431da17e4daebd20ca500.jpeg
is this the RC 2.5 front only or rear too? Truck looks great!!
this would be front only
This is my ‘17 Sierra Z71 SLT crew short bed. 2” HaloLifts coilovers in the front with their rear shocks on a stock block.  I have the +1” block if I do ever decide to throw a shell on the back or find myself hauling more. Running 275/70R18 ko2s on 18” Raceline 946 Boost wheel with -12 offset.  Really wanting to go 295/70 on my next set of tires but really don’t want to worry about having to trim anything. Also have the Diablo tuner set to their 87+ tune. I think the next item on my list will be to replace my aluminum running boards with Go Rhino RB 20 running boards, probably sometime in the spring.
  • 7 months later...
I need to take some pics.
I finally got around to putting on the Bilstein 5100s fronts and rears. I adjusted the front to the highest setting, 1.85”. I’m running Nitto Recon Grapplers and I still have some rubbing at full lock on the UCAs, especially in reverse.
Bought this truck a month ago
Installed rc 2.5 level with m1 monotube shocks all around.
Put on 265 70 17s ridge grapples to replace the stock 20s.
  • 4 months later...
Fuel Lockdown wheels 20x9
LT295/60R20 NIT Recon Grappler A/T
Added 1 inch front spacer to front King Racing shocks and level as can be, rides nice.
  • 8 months later...
IMG_0388.thumb.jpeg.f2416194efa390577f81d10b92982528.jpegI have a 2018 Silverado LT which had a 3” rake and used a 2” front end lift by Moto Fab. I run stock 17 wheels and Yokohama X-AT 265/70R17 OW:10.50.
Next tire change I will go to 275/70.
Edited by David 2018 Chevsil
  • 7 months later...
'14 Silverado LT with 2" RC leveling kit on the front. Has 18X9 +18 Ultra Motorsport Warlock rims with Toyo Open Country 285/65/18. No rubs and did not rub without the level kit.
Owned this truck for 8-9 yrs, then traded in 2022.
Hello everyone, I have a 2018 Silverado Ltz Z71. Currently has stock 20s on it. I have a 2.5 Inch leveling kit with add a leaf in the rear form Auto Spring, as well ordered a set of Bilstein 5100 for the front  to swap out. Id like to run a set of Trail boss rims on my truck, preferably 18s but would run the 20s if i have to. I have had a few people recommend me to run new upper control arms due to the lift. Anyone have recommendations on Ucas? I'm planning on running 275/70r18 or 275/60r20 depending on rim size. I'm relatively new to backspacing/offset stuff. Looking at different Uca's most say you cant run stock rims with some others make no mention. Thanks for the help everyone.
Hey all, I've got a 2015 LTZ 4x4 and have been running a Readylift 2.25" level with the top and bottom spacers. Just ordered the Eibach pro kit this morning after finding a leaky shock. I'll be leaving the clip on the lowest setting for 2.5" and am looking at/wondering if I should also do UCA's. I'd like to improve the ride but more so want to keep my angles right and help preserve ball joints. I've got stock 20" wheels with 305/55 and know I'll more than likely have to throw in a 1" spacer until I get new wheels/tires to clear almost any of them. I've really been looking at Kryptonite and Readylift, also Motofab/KSP/Cognito but the Cognito instructions look like a warning label with max shock measurement, limiting straps, trimming shock tower etc. just so much more than the other companies for whatever reason. I don't care about the price just want the right one that's going to last, if that's a Motofab with Moog's in it, so be it. Any experience greatly appreciated, TIA.
I have the Eibach Pro Truck stage 1 kit on my truck. I have roughly 50k miles on them with the stock aluminum UCA and my ball joints are still tight at 104k miles.
When/ if my upper ball joints need replacing I plan to go with the Superlift UCAs. They are an aluminum arm similar to my factory arms but with increased ball joint angle. Be careful with some of the fabricated arms. They won’t clear positive offset wheels.
