Does anyone have pictures of a 2.5" rough country level kit installed but without the top 1/2" spacer in the front?
Basically just the lower 2" spacer in the front and the 2" block in the rear.
Im looking to get almost level but still keep a slight rake and also not mess with the front springs compression from that 1/2" spacer.
You could just do the 2" front level and You would end up about 3/4" higher in the rear after everything settles out.
There are pics of my truck 1 page back with just the 2" level.
With a 2" level, I fit my 305/65/18s with zero trimming and zero rubbing, even at full lock in reverse. They measure 33.7x12.1, and even .1" more, and it would rub. I think I found the absolute limit for size on these new trucks with just a 2".
How much have you been offroad with that size? They look great!
Hi guys I am new here and been reading this thread this for awhile. I have a 2017 SLT all terrain and was hopping to do the RC 2.5" kit but once I realized that the top spacer goes in the coil instead of the over the strut on the 2017 models I decided against it. I noticed that motofab makes a couple of different options for a 2.5" level kit. I was wondering if anyone has used this kit http://www.motofablifts.com/product-p/ch-25lm.htm ? I also find it weird that rough country makes you conform what control arms you have for there leveling kits but motofab does not? Also I have not found anyone else that makes a 2.5" bottom mount level besides motofab. Is there a benefit from using a 2" spacer on the bottom and a 1/2" on the top instead of just using a 2.5" on the bottom alone? thanks in advance for any help with this!
I had a terrible experience with Motofab. Long story short, they told me the lower strut spacers would work for my '16 and they did not.
Before placing my order, they were very quick to answer all of my qualifying questions, but when i tried to reach out for a refund, I NEVER heard from them (after multiple attempts). Luckily I purchased through amazon, or I would have never received a refund. Moving forward I will go with anyone but them due to the lack of customer service and would advise others the same in case there happens to be an issue.
That said, if you do the top spacer, you should be alright since they are all pretty standard and a solid billet material
Hypothetical question for those more qualified than myself - Trying to get some more height out of mine without having to do a full lift kit
Keep my Bilstein 5100 at the 1.25" setting and do a 2.5" Top strut spacer (totaling 3.75") WITH aftermarket UCAs - would this work?
Or would it be a better option to just do a 1 inch body on top of a 2.5 inch level totaling 3.5 inches?
that would DESTROY your front end components. TREs, BJs, CVs would all be ruined
Can I ask what didn't work with the Motofab on the bottom? I was looking at there 1.5".
Sure. So I was told by a local shop out here (that has about 15+ years or so in lifting/working on lifted trucks) that since I have the stamped steel control arms, the lower strut spacer would not sit correctly. Top worked perfectly and could have ultimately used a motofab top, but i went with pro-comp based on principle.
That's weird. The strut has 2 flat tabs that the spacer sits on. You would think flat is flat. Isn't rough country and all the others the same?
I know people say more than 2.5" is bad for your suspension, but I had a very similar set-up. I had the Rough Country 2" lower strut spacer and the Bilstein's cranked up to the max height, which put me at about 3.75" up front...I didn't have aftermarket UCAs, though I would have added them soon had I kept the truck. I had 285/75r18 Nitto G2s with stock rims and I was off-road quite a bit and no issues. I didn't keep the truck long-term and traded it for a 2500 at about 50k miles, but I had zero issues with my set-up and loved the way it looked.
Edited by atay2011
You dont happen to have any pics of the truck do you? would love to see what it looked like at that size
Here's what I have left of pics:
with NItto G2s 285/75r18, 2" level + Bilstein 1.75"
truck 5
Looks great!
It would put some accelerated wear on ball joints and such, so if it were mine I would replace the control arms...
how did it ride?
Anyone know of the biggest size tire I can fit on a 2" leveling kit 2wd silverado. I'm wanting to go with a 20x10 -24 offset.
TexasSilverado16
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
