Daryl LBZ Posted December 25, 2014 Posted December 25, 2014 I had a catch can on my 2011 6.2L. After catching a decent amount of oil in a small amount of time I'll never run a new engine without one. 1
RyanbabZ71 Posted December 25, 2014 Posted December 25, 2014 Mike norris posted this on FB this morning. They are pumping them out Ryan
RyanbabZ71 Posted December 25, 2014 Posted December 25, 2014 They are a big seller and have been in the sports car market (vettes and camaros) Ryan
Jon A Posted December 25, 2014 Posted December 25, 2014 (edited) Here's what I did with my Elite Engineering can (that's CC-C7Black-Nickel "Good" - Elite Engineering Catch Can - 2014+ Corvette Stingray) for those looking for ideas: Used the supplied hoses and mounting bracket--everything needed was in the box. Literally a 5 minute install, works very well. Very easy to unscrew and empty. Edited December 25, 2014 by Jon A 1
Jay700 Posted December 28, 2014 Posted December 28, 2014 Well tried installing my rx can today. Didn't work I don't have the plug on the top of the throttle body
gone_fishing Posted December 28, 2014 Posted December 28, 2014 Well tried installing my rx can today. Didn't work I don't have the plug on the top of the throttle body Only the 6.2 has the intake manifold vacuum port in this location. See my post #153 on page 11 of this thread for the 5.3 location. See post #21 on page 2 of this thread for V6 installation locations.
Jay700 Posted December 28, 2014 Posted December 28, 2014 Ok how do I get the plug off under the throttle body? I pulled pry alittle too hard and I'm pretty sure I broke it in half. I also don't have a fitting that will snap back on so now I'm pry screwed.
Silverado-Hareek Posted December 28, 2014 Posted December 28, 2014 (edited) Ok how do I get the plug off under the throttle body? I pulled pry alittle too hard and I'm pretty sure I broke it in half. I also don't have a fitting that will snap back on so now I'm pry screwed.It's a pain to get off. I couldn't do it but my brother in law managed to get it off. You need hose clamps to hold the new hose back on. The RX install video fails to address this. If you don't care about preserving the factory hose you could probably cut it and reuse the snap lock fittings but I wanted to be able to return it to stock if I needed to so I used hose clamps to hold the new hose in place. Sent from my iPhone using Tapatalk Edited December 28, 2014 by Silverado-Hareek
bladz1454 Posted December 29, 2014 Posted December 29, 2014 Ok how do I get the plug off under the throttle body? I pulled pry alittle too hard and I'm pretty sure I broke it in half. I also don't have a fitting that will snap back on so now I'm pry screwed. That stock hose should have snap on clips that you need to compress before you pull off.
Crf450r420 Posted December 29, 2014 Posted December 29, 2014 Often you need to push it further on before pressing the clip and then pull
Jay700 Posted December 29, 2014 Posted December 29, 2014 Ya I see that now it's broke now too the stealership too order parts.
