Does new 5.3 burn oil?
bogeypro
Well I am now a little nervous.... I have a 2015 silverado 5.3 with 9900 kms. no issues so far.....but...
My buddy has a 2014 Sierra 5.3 with 55000 kms on it. He started it up this morning and was engulfed in a cloud of blue smoke. Turned the truck off and checked the oil, was way below the low line. He has consistently checked the dipstick for oil use issues, and nothing up until now.
Recent oil change was 2000 kms ago....wonder if this may relate. If so how?
He has warranty changes for oil and uses it within 10-15% of oil life left, which is ususally every 9-11000 kms. Which is what GM recommends.
Any thought or ideas why the 2014 5.3 has burned up so much oil?
EDIT: I would also like to stress that my buddy takes really good care of his vehicle and neglects it in no way possible. No mods, nothing done to the truck at all. We have no idea what is wrong.
It could be many things. Diagnosing an engine problem over the internet is like a doctor telling you how to do an appendectomy over the phone. He should take it to a dealer, leave it overnight in the customer parking area and demonstrate the smoke cloud to the service manager. If it's as bad as you allude, they'll dig into it. New PCV valve (he can do that, if he's inclined), compression checks, valve stem seals. That's my short list.
  • Replies 119
Agreed.
Just wondering if anyone has experienced silimar issues to date with oil consumption. He will be bringing it in within a few days.
Thanks!
Agreed.
Thanks!
Dave,
I've been on these forums for years. Oil burning is all over them, regardless of brand, model or engine. Decades ago, in the early 70s, I recall a Ford Pinto our family had. It burned about a quart every 1000 miles. The dealer pulled out a Service Bulletin that showed that 600 miles or more to the quart was acceptable before warranty action.
My old 99 1/2 GMT800 2500 6.0L (1st year LS engine) would puff a little cloud out on cold start after it got 50,000 miles on it. It rarely took a quart between the 5000 mile oil changes, but it got low. That truck was still going strong at 225,000 miles when I sold it. Today, it belongs to a friend and he has close to 300,000 miles on it. The engine hasn't changed it's rate of oil consumption. Mobil 1 from the 1st change. I run M1 in my new truck and the 2008 I had in between.
Dave,
Some awesome info! I am used to burning a little bit of oil in my KTM, but this truck is my first new vehicle so I was concerned to see buddy's truck start using a little. Mine has not yet, who knows if it ever will. Also, I have warranty for another 4 years which is great.
Thanks Again!
I just cannot endure oil burning engines. Too old fashioned I reckon, when none of my vehicles ever used oil. My '93 Dakota 3.9 V6 with over 200,000 miles still does not use any oil! None. I loved those 350 GM engines! My '96 got almost 20 mpg highway. Other than the notorious intake manifold gasket mess with those years, they were rock solid. I wish GM would just make those again. I imagine my '96 350 hooked up to a modern transmission would get over 20 mpg highway.
I had a '90 GMC 350 TBI that would use about half a quart between changes every 3000 miles. Old tired motor that I pushed hard every single day.
I still have my '99 OBS 4x4 and it used a quart every 3000 miles like clockwork up to rebuild. Rebuilt as a 383 with a torque minded cam (high lift, low duration). Broke in properly, still uses at least a quart every 3000 miles. But it is/was used as a truck (hauling, towing, farm truck things) up until a year ago when it got "retired". It just sits around mostly now.
I had a 2005 Silverado L33 5.3 "H.O." I bought used, so I can't say how it was broken in. I used Castrol 10w 30 in it. Daily driver and work/play truck. Used a quart every 3000-4500 miles.
Almost every V8 pickup of every make I've been around uses 1/2 quart to 2 quarts every 3000-5000 miles. By design, engines will burn oil as oil will cling to cylinder walls during combustion events and exhaust events, lubricate hot parts and either burn or evaporate (coke) off, etc etc.
And don't get me started on diesels...
I check the level when I'm ready to change, and every time so far not a drop used. I change right around the 5,000 mile mark when the oil life is about 30%. I have close to 25,000 mile now. I've only WOT for a few seconds maybe a handful of times in those miles. I don't have a catch can yet. Do I need one, maybe, maybe not. But plan on one anyway.
For what it's worth, I think my rings are seated very well. I have a very steep long hill I decend every morning. From new, I always put the truck in 2nd and just let it hold the truck back all the way down. Never have to worry about anyone behind me because it's rural and 4:30 AM No traffic. I think that played a big part in breaking this engine in properly. I hope so anyway. :)
  • 1 month later...
I had a '99 2500 Silverado with a 6.0L and it used a little over a quart of oil every 3,000 miles or so since the day it was new. The dealer told me that was acceptable. When I traded it in on my '14 1500 Silverado with a 5.3L it had 176,000 miles on it and burned exactly the same amount of oil as new. My '14 has 21,000 miles on it and it doesn't burn any oil at all.
4640 miles and dipstick shows completely full. Oil is still golden honey color.
Ive got a 2015 and have just under 4000 k and am in the same boat as above
my 2006 sierra 5.3 used a litre between oil changes form the day I bought to the day I sold it with 350000 kilometers on it. changed oil every 5 to 6k. my 2014 chev 5.3 seem to be the same I have 30k on it and 9k since last oil change and it has use about a litre and a half
I have 30k on my 14. No burning oil. What I have noticed is that if I park the truck in the garage (level floor) and shut it off and check the oil it looks like 1/2qt low. If I let the truck sit for 15-20 minutes go back and check it..... at the FULL mark. Something is holding oil in the upper end. I thought I was burning oil. Just need to give it 15-20 minutes to settle. I've never had to add any oil in between oil changes so far. I had the dealer do the 1st and 2nd oil change and then I have done a change on M1 and Valvoline Synpower. All 0w-20 full syn. I'm due for a oil change in about 3 weeks which will put me at 31-32k. Planning on running more 0w-20 Synpower and a M1 filter. I've been running all AC filters except one was a P1. I'm sticking with AC or M1 for a filter. Champ labs.
15 minute sit time is SOP for checking the oil. OM may call for it. Nothing holding up the oil, just takes awhile to work its way down and all parts to drain their oil coating. I would still advise a catch can to keep as much oil as possible out of the intake/rings and to slow valve caking on the new DI engines. New Camaro will come with a GM designed catch can. Hope they have the oil burn and AFM lifter problems finally fixed in the newer trucks.
    Frank V
    Frank V
  • Who's Online   7 Members, 0 Anonymous, 1,225 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
