Does new 5.3 burn oil?
bogeypro
I have a 2014 that i just bought with 23k on it...it burned 3&1/2 gts in 2200 miles...took it in 5 times for oil consumption test and now they are saying the low tension rings arr bad...they are supposedly in the process of putting new rings and pistons in a truck that only has 35k on it....my 99' sierra has 225k on ot and wont burn a 1/2qt in 7k.....pretty sad
Just curious if anyone has driven enough yet to notice if there are any oil consumption issues...Sent from my HTC One mini using Tapatalk 4
  • Replies 119
Naah. This is the new norm in the automotive industry now. Low tension rings to get better fuel economy and primarily on direct injection engines = more oil consumption. Yes the oil consumption does happen on non-DI engines as well but very noticeable on DI engines. Add to that the EGR crap as well.
My 2014 Sierra 5.3L burned through 4 qtrs in 7k miles, at 34k miles and didn't have a clue. Now I'm at 45k miles and I'm burning between 1-2 qts every 3k miles and the dealer is telling it's normal.
Well it is! As sucky as that is.
Well, then my 5.3 must be defective because there is no oil consumption between 7,500 mile OCIs
No, it's not defective. It happens on some and on some it does not happen. And you can argue that to the dealer and manufacturer until you are blue in the face and it won't make a difference. It happens.
  • 4 weeks later...
I dont know if anybody has the miles to tell yet. They say with new engines you might get some new burn off. I have a nasty feeling thats why GM has an 8.5qt oil pan now.
When I see how GM tends to "fix" things nowadays, maybe they will go to a 22 quart engine oil capacity next just to be on the safe side. After all, that's what the old military deuce a half trucks have.
They are using EGR valves again? I do not think my 2006 Silverado 5.3 engine has one of those.
I have 22K miles on my truck and it doesn't burn any oil at all. I drive it hard, especially on break-in. Every vehicle I've ever seen that was broken-in "easy" burns at least a quart of oil over 5k miles. Only solution is to replace the rings / hone the cylinder.
The rings need to seat/wear up against the cylinder wall and the first 100 miles is critical. This process should involve varying the RPM (no constant RPM) and having load on the rings. Constant Acceleration and Deceleration provide the best load on the rings. Make sure this is on a warmed up engine (doesn't have to be fully warmed up, 120-135F should be fine).
Synthetic oil that comes from the factory is actually bad for ring seating and can cause the cylinder wall to glaze if driven too easy.
After about 500 miles do an oil change, don't wait 7.5K for that first oil change. I gradually increased mine (I was lazy and did it at 1000, 6000, 13000, 22000).
I can't take 100% credit for this information as I based it off of motoman's break-in secrets for small engines and it hasn't failed me yet.
  • 2 years later...
My 2019 silverado with 30000 miles burns 1 qt every 2000 miles.  Dealer printed me some bs bulletin made 7 months after I purchased it sayin the allowable oil consumption rate in there spec is 1 qt  every 2 thousand miles... it has been a headache goin round and round with them...  I've been a chevy owner all my life and never had problem with older models...   is there anything g I can do about this or has any one found a solution to the problem???
Welcome to the life of Direct Injection engines.  they burn/consume oil.  Yes, 1 quart every 2000 miles is perfectly normal and most manufacturers say acceptable.  If you don't like it, I'd suggest you go look at another brand that doesn't make a direct injection engine.
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
