Here's my 2014 SLT 6.2 and my 2011 SLT 6.2. Got tired of waiting for my max tow 6.2. Love it so far.post-123886-0-08504900-1385600451_thumb.jpg
Edited by dlockwood26
Here are some updated pictures with the N-Fab Bars installed. If you are considering any step bars or light bars N-Fab is the way to go. They fit perfect, the welds are excellent, and the paint quality is terrific as well. There is no comparison to the oversized factory bars.
http://n-fab.com
  • Like 4
I guess I have kinda, sorta broke the code. I'm sure I still don't have it right because this is currently a seriously painstaking process to get the picture from photobucket to the forum. Either case, this is my 6.2 Denali. I took delivery on Nov. 7th and have made numerous mods since.
Here's one more. I'm done! Next time, I'll be able to post pics all in the same post. These were experiments. Sorry for the three separate posts but that was the best I could do today.
Mine with all the latest additions.
Color matched mudflaps
Weathertech window visors
Chrome grill
Bowties plasti dipped
Future:
Full exhaust
Tune
Under seat storage box (should be here today)
Hey can you post pics of your Katzkin leather back seats? Thanks. I appreciate it.
pretty crummy pic, but they look exactly like the fronts
Here a quick picture of my loaner Sierra while I wait for mine to be done. I get to do all the things I would never do with my own truck with this thing and it takes it all.
New to the forum, here is my 2014 Silverado LTZ Crew Cab 2WD, Fully Loaded. Silver Ice Metallic with black perforated leather seats. So far I've swapped out the oem chrome mesh to a black oem mesh grille, I have color matched handles I need to install and I've done a little debadging. Getting 5% tint and a bed liner next week, lowering shackles to level the rear. I'm really wanting to find pricing on an OEM GMC All Terrain Rear Bumper without the steps, but have had no luck so far.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
