The highest I have ever got was 15.6. I am about 60/40 city though. I understand that city driving is worse, but to be 3 mpgs worse, at my best, then what city is supposed to be rated at is a joke. My last tank I was at 13.1.
My "best 25" is 21.8 "best 50" is 20.1, "best 400" 15.1. 3500 miles and my mileage gets worse every single fill up, like I said my last tank was 13.1.
I also watch my mileage the whole time (and my fmaily thinks I'm nuts and laughs at me the whole time), and drive like a Grampappy. Coast when ever I can, and drive 65 (70 mph speed limit) on hwys, 45 (55mph) on country roads most of the time. I've never drove like this and it's starting to not be worth it, I wanna ripppp!!! :driving: lol
Fellow Michigander, your MPG is only going to get worse with these cold temps and snow.
I understand that too, but if I drove this truck like I would normally drive I'd be under 10 MPG. Thats just silly.
Yeah don't get me wrong, I do like my iridium but it's not exactly the color I truly want. But it's close. And yeah black wheels on grey or charcoal paint is my favorite setup right now. Then all black is my second choice. Ford has a grey I like. I just am not much of a Ford guy. Except the raptor is sick.
I have always had all black. So I decided to switch it up and try the Iridium, pretty happy the way it turned out. My biggest complaint about these new trucks, is the damn paint is ridiculously thin!
Edited by John_chadra1
  • Like 4
Was at the hunting camp this weekend and thought id take a couple pictures.
693389AE-7FAD-403E-B6A2-4C537740A5E9_zps
2DC3BA20-BFC2-43A8-B85C-4CDD9944E510_zps
  • Like 12
Excellent looking truck Joel! Given thought several times to that 3.5" rough country kit. Though buddy of my brothers running his older 2011 GMC with that kit plus trail grapplers was getting horrid gas mileage.
How is yours doing?
I think my truck is on the low end of the spectrum when it comes to the 14s. I'm getting 12-15 in town stock and 18-20 highway at best. It's more like 13 city, 17 highway.
Thanks will! I am continuously adding things to it because I'm sure you and everyone else on here knows, you're never completely satisfied with how it looks you always want to do more! up here we go by litres per 100 km so im not sure exactly the fuel mileage but I can tell you it has definitely taken a significant hit
Looks great... did you clean it up once you got 2 the camp?? I would've
Thank you!
No, shes actually dirty in those pictures. Its just hard to tell with the truck being silver.
Edited by Tim99GT
better do it now when gas is cheap. Only going to go up from here. Last time I remember 93 being $2.50 was in '05.
Here's my bone stock 2015 Sierra All-Terrain "before" pictures for reference. Plans are 2.5" RC kit up front, gonna leave the stock blocks in the back. I'll swap for the RC blocks if I have less than 0.5" rake or looks "nose high".
It's also getting 295/55r20 (33x11.5) Toyo AT2 Xtreme tires on stock 20's and black Bulletproof offset mud flaps. Should be done after the weekend, I'll report back with "after" pictures and measurements.
Here's a little bit of an update, got the Rough Country 2.5" kit installed up front and the 295/55r20 Toyo AT2 Extreme tires on.
Decided to leave the stock blocks in the back for now, had the shop send me a couple pics and take a few measurements.
Currently sitting at 39.5" up front and 39.75" out back from ground to center of fender.
I'll give it some time to see if it settles and if I change my mind I can easily swap the rear blocks.
Just have to get the BulletProof offset flaps on, tint the front windows and get the front bumper PPF installed.
Hutch what were your original measurements? I've been thinking about getting a 1.5" block if i don't have a half inch of rake or better.
Unfortunately I never got a chance to measure it before the work was done... and every truck seems to be a little different, especially with different cab/box configurations.
Here is the specs from a 2014 Silverado 1500 LTZ Crew Cab Standard Bed with the full RC 2.5 kit and 305/55r20 tires:
Stock height with 275/55r20: 37" Front 38.75" Rear
Leveled+Block with 275/55r20: 39.5" Front 39.75" Rear
Leveled+Block with 305/55r20: 40.25" Front 40.5" Rear
His seem to be lower in the rear, but that could be due to the added weight of the longer box. I know the Ext Cabs tend to have more rake than a crew cab.
There's a couple members with the RC 2.5 kit and the general consensus is that on a crew cab with a stock rear block you'll be about 0.25-0.5" higher in the back.
One member with a 2" front only is sitting at 39/40, another like mine with the 2.5" front only is 39.5/40.
In theory, if I swap the rear blocks I "should" have approx. 39.5/40.75 fender measurements with 1" - 1.5" of rake.
So depending on what you want, it sounds like the supplied 2" block will be enough to give you the rake you're after... or just leave the rear blocks and only do the 2" front kit.
Here is a walk around video with up close of the level kit.
That rendition of Metallica is hilarious.
I had to turn the sound off, it was too painful to listen to.
Agreed...and I REALLY LIKE Metallica...when it IS Metallica.
Edited by patriot
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
