Good to know... I measured the Rigid Lights at SEMA and the height of the lights are 2" not including frame.... The Gaps in the AT grille are exactly 2" but I would love to see how it would fit before purchasing.
Im sure you could make it happen if you really want to. Light would shine through the slots in the grille for sure, but some of the LEDs might be covered up due to the curve of the grille. Its hard to explain, but i did it on my 2007 NNBS Sierra with a 20" Rigid double row light bar and i will attach some pictures. I measured the grille slots on my old truck just like you said you did and if i can remember correctly the slot was around 2 to 2.5", just f653b5dc6f9bf05039c4c69b180db641.jpg1887d933071139ac73a47b1101f6acfd.jpg08162ac1753ec016228a5b0a1d84ee00.jpga little bigger than the 2014 grilles, so I decided to put one it thinking it would fit, but the curve of the grille covers up some of the LEDs so i trimmed some of the black plastic off the grille to try and make the LEDs all shine through. But if you really want to get that double row then go for it. If theres a will theres a way
Got her all cleaned up
Is that black vinyl between your windows on the doors? Ive been wanting to do this for a while but I'm trying to decide what to use
Yes its gloss black. I think it gives it a cleaner look
Yeah it looks more like its one big window and thats what I'm going for. Where did you get yours and how has it been holding up?
I got it from a local shop. Its made by a company called ritrama. Its holding well. I just pressure washed it and it held fine.
Wheels are Fuel (Mavrick) 20x9 machined finish and tires are factory Goodyear 275/55/20's
IMG 0764
Anyone have pics of the inner and outer chrome 2014+ grill painted black? I have been out of town and have my grill scheduled to get color matched. I am temping to paint the inner chrome parts too or just replace with a new grill. I seen it on a white gmc where the whole grill was painted gloss black on a white truck. It looked sikk but don't know if it would look good on silver. I love the color matched AT grill / bumper and still hunting a set down. Hoping to score a silver set. I just don't trust chrome bumpers painted. I also have a titanium matte wrap on my mind but don't know if I want to commit to a full wrap . d35a3bf612d39bdf5118bba3c17bf288.jpg
I finally got a picture this weekend. It was nice enough outside finally to give her a wash.
what level?
Thanks Will!
It has a 2.5" "level" kit and the trim "level" is SLE with all/most of the option packages minus tow, leather, heated/cooled seats. With my previous truck heated seat were a must with leather IMO, but I don't miss it at all with the cloth seats.
Put my RC 2 inch leveling kit on mine this weekend. Brought it up 2 1/4 inches in the front. For those of you that have installed it yourself did anyone have as much trouble as me getting the ball joints to separate. Had to go buy a ball joint separator. I have a z71 4x4 with rancho shocks and mine didn't go near as easy as all the videos I saw. It looked like the lower a arm is a little different on the 2014s which made it seem like it was much harder to pry the shock over the spacer. I was doing it myself so that may be why. It definitely wasn't an hour and half job like some have done on here. I spent that almost on the first ball joint and then the other side started so I went and got a separator. Broke the rubber thing to do it so probably won't hold grease to well so probably be replacing a ball joint sooner than normal. Not sure if pics posted
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
