Sure. I located two High Country grilles on EBay from dealers near me. But before I pulled the trigger, I noticed a High Country take off grille in the For Sale section. A member in NY had it taken off and replaced it with a color matched grill when the truck was new. He shipped it to me using the replacement grille's box. Used Paypal for payment. After the HC grille arrived, Took me about 1 ½ hours. Hardest part was getting to the 4 bolts that are underneath the bumper (behind headlights). I followed these instructions and video...
http://www.gm-trucks.com/forums/topic/156014-2014-silverado-grille-removal-how-to/
Here's the one I bought. Got my color matched door handles and mirror caps from another For Sale listing on here.
http://www.gm-trucks.com/forums/topic/180599-for-sale-front-grill-2015-high-country/
Nice... Thanks for the links and Info..
Love that blue. I was on the fence between the blue and the Tungsten Metallic.
looks good, what size are your toyos ?
they are 305/50/20. so they are a little taller than the stock tire set up, but it only throws the speedo off by 1 MPH at 70 MPH. at 50 it is only off by .6. I also wanted an offset that sticks out of the fender a little bit and did not want to worry about rubbing.
It will be awhile before they wear out but next time I might replace with 295/55/20. I think they should clear without rubbing and at that point when the truck isnt brand new, I won't be as concerned with the speedo. I installed these with 500 miles on the truck.
very happy with the set up so far
12301735_10100974358744406_5930562015513
Edited by emeryz28
Your truck went to the gym? :):)
Well... I went to the gym... Truck went to the gym yesterday and got a new exhaust.
See...
Edited by tyrich88
Been looking at all the truck pictures for a while now. I finally got around to posting pics of my 2015 Silverado.
11219578_10153135541811176_4359566454124
I like chrome when its do like this, nice setup!!
Oooh. I like it.
What width and offset are your wheels? Looks sharp.
Before and after snugtop. 2016 slt Z71
Sold my replicas earlier today, and back on stock. New shoes coming tomorrow [emoji41][emoji106]7c694995e8f181a0f507db7e35db444a.jpg502d32c7ea84fd484224c2b399e78f1e.jpg
thanks!
20x9 + 1
305/50/20
2014 High Country 6.2L, CAI Intake, Corsa Sport catback exhaust, Diablew custom tune, Rough Country 2.5" leveling kit w/ 1" rear blocks.
  • Like 5
looks good . to much crome for me . may be a BLACK bowtie ?
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
